What tools are you guys using for lifters and valve springs during cam install?
i know i have seen the use of metal dowel rods to hold the lifters up. can anyone tell me what size and where to get them from?
what valve spring tool is everybody using? is there a cheaper alternative to the $129 thunder racing tool and the $100 comp tool?
the cam install is costing me enough and was just wondering if someone could point me in the direction where i dont have to spend $200 on specialty tools.
thanks
thanks
i used 5/16 brake on one cam install to hold the lifters, but iv done 4 or 5 cam installs after that without using anything. for the valve spring tool i used a piece i bought on this forum called tim's tool i beleive cost around 35 bucks. and instead of using a compression kit to hold the valves up, i just used the tops of the pistons.
Have just relied on the lifter cups to hold my lifters up, but that is taking a chance....5/16" towel, wood or metal should work great... just take the cam gear off, the the cam cover plate and slide each towel in the lifter oil bore holes all the way to the back of the motor ( might need to rotate your cam a few times)
One of my friends made a metal plate out of 3/8" steel with a notch cut out of it for the valve locks and bolt hole in it that uses the rocker bolt hole and levers against the side of the head to install/ uninstall valve springs....use a compression tester fitting and hook it up to your compressor ( keep air to it the whole time) to hold the valves closed if your swapping springs with the heads on the engine
Google McMaster Carr, they are an online hardware vendor. Bought 2 - 5/16" alum rods 36" long for about $22 plus $4 shipping. Worked great. Shipping was about 2 days. We order from them at work all of the time.
I bought the Comp cams compressor from Thunder during the sale. Talk about making a spring swap fast and easy...I have the TREX in and waiting to get the pistons flycut. Hopefully I can fire her back up this weekend.
if you can weld one of the best valve spring tools ive seen is a old rocker thats been modified with arms welded on to sit on the retainer and then sockets welded to the sides to turn it, my local lsx shop made it up and use it all of there cars and is amazing, im going to make a few once i have extra time
I just did this job. If I ever do it again I will just pull the heads. Don't cheap out on the lifter tool, get a new one and do some searches on here. I used the rods, but they never held up the lifters so I used pen magnets as well. This is not the right way to do this job and I wouldn't recomend it. As for the spring compressor, sure make your own or get one half price on here. I am changing the power steering cooler at this time as well. Fire it up later this weekend. Make sure you have all your parts and give yourself lots of time. Good luck.
You know, I have never once heard of a lifter falling out of a tray during a cam swap. Not once. I'm sure it's happened, but I've never heard of it. I know a lot of folks who swap cams that way.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
1/4 or 5/16" dowel rod, brake line works too. I just used Tim's Tool on my valve spring swap and it worked out nicely. Also I used the air fitting with my compressor to lock the valves in place. It was kind of a pain to thread in to the spark plug holes, I ended up making a shorter hose for it
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
I like using the compression tester with the air compressor hooked up to it...but be sure to keep air to it till you get the spring and lock back on the valve.
