View Poll Results: Which cam should i get
Comp cam 228/230 .571 .573 112lsa
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
23
56.10%
Patriot 226/226 .585 .585 112lsa
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
1
2.44%
get another cam.
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
17
41.46%
Voters: 41. You may not vote on this poll
Decision time: 228/230 or 226/226
#44
first off, consider what heads you wish to run. the whole point of running a split-pattern cam is to compensate for the exhaust port's inability to flow as much as the intake side.
point in case, i'm running a 228/230 for an off the shelf AFR205, which has large enough exhaust ports to warrant a single pattern cam. at least that's what i understand. but i still make great rwtq numbers.
