Help me pick a Cam PLEase
Old May 9, 2011 | 10:16 AM
pyro719's Avatar
Went with an EPS Grind 226/234 .598/.602 113 lsa
Old May 11, 2011 | 11:00 AM
pyro719's Avatar
Will I have to worry about ptv clearance with this cam?
Old May 11, 2011 | 11:05 AM
KevinR's Avatar
I very seriously doubt you will have to worry about it with that cam. But, might as well measure, better safe than sorry.
Old May 11, 2011 | 11:28 AM
mattster03's Avatar
no. not unless you have aftermarket milled heads or thinner than stock gaskets.
Old May 11, 2011 | 11:36 AM
180ls1's Avatar
not with stock heads, you will have plenty of room.
Old May 11, 2011 | 04:59 PM
pyro719's Avatar
Awesome! didnt think it would be an issue but never hurts to ask
Old May 11, 2011 | 08:15 PM
*02WS6TURK*'s Avatar
Nope. You will be just fine.
Old May 12, 2011 | 08:33 AM
SEMI-RETIRED's Avatar
How could the lobe design between tsp and eps be different?
If a person would order a cam from comp or cam motion or whoever how would it be any different than what tsp or eps would send us may be a better question?
I do not mean to pick on any company obviously the experience they bring to the table is way better than what many of us have to offer but with that set aside what do you think the difference may be if any.
Old May 12, 2011 | 08:46 AM
01ssreda4's Avatar
Everyone uses a different variation of the lobe. Everybody pretty much gets their cams from Comp. Except Futral, he gets his from Cam Motion. Search "Cam Motion" on this site as we have discussed lobes between the vendors many times in the past.
Old May 12, 2011 | 10:48 AM
pyro719's Avatar
EPS lobes are exclusive to them from what I understand.
Old May 12, 2011 | 10:59 AM
kinglt-1's Avatar
This...but they are a comp lobe "lsg"
Old May 12, 2011 | 11:26 AM
  #32
01ssreda4's Avatar
Again, this has been discussed in great detail pretty recently. The LSG lobe stands for Geoff at EPS. Comp will not cut that lobe for anyone else. TR has its own lobe, Cam Motion uses their own lobe, and Futral has CM cut his lobes how he wants them. Each cam is unique to say the least.
