ls2 heads on a 5.3
Old Apr 25, 2011 | 10:08 PM
86 g-body's Avatar
Default ls2 heads on a 5.3
i have a set of 243 heads is it worth the trouble of instaling with a ls6 cam??need to know before i sale these heads
Old Apr 25, 2011 | 11:05 PM
kinglt-1's Avatar
the 243/799 castings are the same thing essentially. Gm used the 799 on the aluminum blocked 5.3. So yes they will work fine!!
Old Apr 26, 2011 | 08:56 AM
Jon@Texas-Speed's Avatar
They will work but you are going to be giving up some compression to the stock heads but gaining some airflow. If you decide to install them, I would mill them to try and gain some of that compression back if not gain some. With a LS6 cam, you should be room to do some decent milling to help out on the compression.
Jon
Old Apr 26, 2011 | 08:24 PM
86 g-body's Avatar
will it be a big rwhp gain compaired to stock with the ls6 cam and ls1 intake and tb??
Old Apr 26, 2011 | 08:37 PM
tripblackls1's Avatar
only if you mill them if you dont the loss of comp will pretty much negate the gain in airflow
Old Apr 26, 2011 | 10:57 PM
86 g-body's Avatar
ok with the heads milled what would be my rwhp ???
Old Apr 27, 2011 | 07:47 AM
boostnut's Avatar
Are these the same 243's that you've already agreed to sell me?
Old Apr 27, 2011 | 08:08 AM
ISMELLRICE's Avatar
lol..
