Dynamic Compression
Old Apr 26, 2011 | 01:50 PM
Kaane's Avatar
Default Dynamic Compression
Can someone calculate DCR for me for this combo?
Stock Ls1 shortblock, 60cc heads, TSP 224R 114LSA Cam. Stock MLS headgasket.
Old Apr 26, 2011 | 01:56 PM
'00Formula's Avatar
Depending on the advance ground in, between 8.5 and 8.8ish
Old Apr 26, 2011 | 02:02 PM
Kaane's Avatar
6.84 is way too low. Something is wrong.
Old Apr 26, 2011 | 02:41 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
So long as you didn't order it "custom" with a different ICL than standard, you will net about 11.1:1 static, and about 8.7:1 dynamic.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 26, 2011 | 08:22 PM
Kaane's Avatar
8.7:1 hmm.... a bit high for 91 octane. Should I change cam or run a thicker head gasket? or just run slightly less timing?
Old Apr 26, 2011 | 09:00 PM
A.R. Shale Targa's Avatar
Running a thicker head gasket is almost always the wrong way to reduce the
compression. Perhaps get the TSP 231/234; seems real popular, nice idle,
and very streetable with the right tune. You have enough static comp for it
to work well
Old Apr 26, 2011 | 11:08 PM
Isolde's Avatar
How is any of this useful without knowing what elevation the OP lives at? In Denver, you can run more DCR on 91 octane than you can in Death Valley.
Old Apr 27, 2011 | 01:02 AM
oakley6575's Avatar
How much dynamic compression can you run at 2000 feet with 91 octane??
Old Apr 27, 2011 | 01:23 AM
Kaane's Avatar
Sea level. I am in socal.
Old Apr 27, 2011 | 09:54 AM
I'd agree it'd be more beneficial to retard the cam rather than running a thicker gasket!
__________________
Old Apr 27, 2011 | 12:02 PM
Isolde's Avatar
The real issue is the cranking compression. Going for, say, 200 psi ( safe on pump premium ) takes both more SCR and more DCR in Denver than in Death Valley. But 200 works wherever you are in this nation.
