Milling heads with MS3?
Old Apr 30, 2011 | 10:27 AM
brian_rs/ss's Avatar
Originally Posted by tnmotown
It's cam only in my eyes even if I mill the stock heads, but I don't wanna go in that subject as I always do with the ford guys lol.
Like I stated in my first post this is on a budget build so porting is out of the question right now.
hmm ok so milled 241's and i'm assuming an ls6 intake? 4L60, w/ what stall? 10 bolt? what gears?
you might search around for the EPS 226/230 it's been a fairly popular "cam only" grind from them. you could possibly go a little bigger than that but i would def talk to pat first.
Old Apr 30, 2011 | 11:58 AM
180ls1's Avatar
If you do the fly cutting yourself it can be a very safe and cost effective way to increase compression which will be a good thing for that setup.
