Milling heads with MS3?
Old Apr 26, 2011 | 11:03 PM
tnmotown's Avatar
Default Milling heads with MS3?
Ok guys I got a stock ls1 short block with a ms3 cam. I'm currently gonna get some heads weather they be stock 241's or if I can find a good deal on some 243's. My question is....what can I mill these heads down to without running into problems with flycutting? I've tried a search and only seen a few people with stock ls6 heads (64cc?) and the ms3 cam. I want my CR around 11:1. and its also going behind an auto tranny if that matters.
Any input would be great and I don't want to spend lots here and there as I'm trying to keep this a budget build. Thanks!!!
Old Apr 26, 2011 | 11:40 PM
tripblackls1's Avatar
i would ask tsp but i dont think so, i know i had to flycutt atleast .080(recommend by tsp) when i had my ls6 heads milled .040 with my ms4 and the ms4 is not much larger then ms3
flycutting is usally cheap though, i paid my local shop 150$ to do it
Old Apr 27, 2011 | 12:27 AM
tnmotown's Avatar
Yeah I might have to give them a call but just seeing if anybody has personal experience going this route.
Also would 2.05 intake valves make a difference? I might of rounds some decent heads that are 65cc but with bigger intake valves.
Old Apr 28, 2011 | 05:48 PM
tnmotown's Avatar
anybody else? Does everyone pretty much keep the stock head cc's when going with a ms3 cam?
Old Apr 28, 2011 | 06:09 PM
mark21742's Avatar
I ran a Trickflow 238/242 with .040" milled off my 241s.....ran great but when I pulled the motor down to do some other work on it you could see where the valves had just kissed the pistons a few times....no damage but I got lucky
Old Apr 29, 2011 | 12:45 AM
brian_rs/ss's Avatar
.051 gasket? i think this right here is your answer OP. either way you should not hesitate to check the clearance.
Old Apr 29, 2011 | 12:51 AM
i really don't think you have a need for 2.05 valves....just sayin.
generally speaking, yeah kinda. seeing as how the ms3 is/was regarded as one of the best cam only sticks out there.
not generally speaking, i know there are a lot people that fly cut with milled 243's and either this cam or something similar in duration, with great success. but despite what everyone else does....just check to be sure.
Old Apr 29, 2011 | 04:45 AM
mark21742's Avatar
Yup .051" gasket......like I said, o hot very lucky I didn't bend or break anything...and that was stock valves
Old Apr 29, 2011 | 09:39 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I would not go more than a few thousandths to ensure they are flat. Any more than that is just too tight for comfort, IMO!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 29, 2011 | 06:30 PM
tnmotown's Avatar
hmmm.....I'm in a bind here. I wanna keep the ms3 but also want to bump my CR to 11:1.
I guess only way to get to that is flycut and still check clearance like you guys said.
Hey Matt, what about your TSP 233/239 cam? I might want to go a tad smaller and would that cam be easier to mill heads and bump up my CR?
Old Apr 29, 2011 | 07:20 PM
mark21742's Avatar
Is flycut and be done with it, that way you can go with what you want
Old Apr 29, 2011 | 07:30 PM
180ls1's Avatar
you wont really have any room to mill unless you flycut.
Old Apr 30, 2011 | 02:48 AM
are you stuck on XER lobes? you might consider less duration with similar lift to an ms3. there are plenty of lobes out there that can still allow you to mill and you wont have to fly cut.
for my build pat spec'd me out an EPS 230/234 .600/.609 112 lsa cam. i told him i wanted to mill down to about 60-61cc's and that's what he sent me. it may not be a bad idea to consult a pro on this one.
Old Apr 30, 2011 | 03:09 AM
tnmotown's Avatar
Honestly I'm not to familiar with XER lobes. I just wanted to try and get my compression up to help out on the responsiveness of the ms3, since I heard it's kinda a dog down low.
I PM'd pat g a couple days ago but still haven't heard anything.
So with less duration then the ms3 but around same lift, you think I can get about the same hp gains? I've researched flycutting and seems too much for me to do.
Old Apr 30, 2011 | 03:23 AM
yeah sounds like you are trying to build your engine around the cam. you need to consider ALL of your build specs and goals prior to chosing a cam. the ms3 is sort of peak-ish. if you want some more low end then have a cam spec'd out for that. compression is great, but shoudln't be used as a band aid for a cam profile that is not ideal for what you want. the ms3 has it's place don't get me wrong, it just seems as though your wants/needs don't match up with the ms3.
pat is a busy man, took him a few days to respond to my emails as well.
and to answer your question, yes. less duration and about .600-.610 lift would still see a very nice curve, a little more low end, and should save you from having to fly cut.
Old Apr 30, 2011 | 03:53 AM
owndjoo's Avatar
i've got a set of .040 milled 5.3 heads for sale from prc. 11.4:1 approx. comp.
Old Apr 30, 2011 | 07:33 AM
mark21742's Avatar
if it make you feel any better I'm building a 12.5:1 compression 408 right now for pump gas and daily driving
Another option you have is to run a slight dish with valve reliefs and find someone in your area to weld your chambers then CnC them to get the compression you want...this way the majority of the pressure is on the center of the piston right over the rod and not being pushed out towards the ring lands.....this is your best option
Old Apr 30, 2011 | 08:58 AM
tnmotown's Avatar
Well the cam was in the motor when I bought the short block. It's gonna be a cam only only car with maybe some juice. That's probably why it seems like I'm building around the cam.
It seems like for me to bump up my compression with out fly cutting I'll have to go with a little less duration cam.
Old Apr 30, 2011 | 10:07 AM
if you are going to mill, then you are no longer "cam only". and if you do mill then why not just go the extra mile and port them?
Old Apr 30, 2011 | 10:14 AM
tnmotown's Avatar
It's cam only in my eyes even if I mill the stock heads, but I don't wanna go in that subject as I always do with the ford guys lol.
Like I stated in my first post this is on a budget build so porting is out of the question right now.
