lbs injector?...
Old Apr 27, 2011 | 03:44 PM
z28strong's Avatar
Default lbs injector?...
i gotta TSP 228R cam in a 98 camaro wit a ls6 manifold ported and polish wit the heads and a 85 throttle body wats a good lbs injector to go wit
Old Apr 27, 2011 | 06:51 PM
mark21742's Avatar
36-42 lbs would work good for you
Old Apr 27, 2011 | 07:04 PM
TransWS6Am's Avatar
you would probably be fine with the stock injectors. whats your duty cycle at wot? if not you probably only need like a 30 or 32.
Old Apr 27, 2011 | 08:14 PM
Mac 2002 SS's Avatar
FAST 36 lbs injectors will do just fine.
Old Apr 27, 2011 | 08:22 PM
mark21742's Avatar
I recommend the 36-42 lbs injectors, because if you go more radical later you won't have to buy bigger injectors again later. If your injector duty cycle on your stock ones stay under 85% I'd keep them, but only way to know is to log them
