Explane lifter preload and why and how I do it ....
Old Mar 4, 2004 | 08:14 PM
SSEUL8R's Avatar
How do you check lifter preload?
Old Mar 24, 2004 | 12:50 AM
Cal's Avatar
Cal
Lifter preload on LS1's is usually measured in the number of turns you get on the rocker bolt from the time it gets hard to turn until the time it bottoms out. That number of turns should be from 1/4 turn to 1 1/4 turn. Pretty wide range . . .
