torquer v.2 retard or advance
Old Apr 28, 2011 | 06:22 PM
oxblood!z28's Avatar
Default torquer v.2 retard or advance
Ive got my timing chain exposed right now and was wondering if I should advance my cam to get power sooner...I've read that TSP torque cam v.2 opens up later in the rpms so I'm thinking I should advance it to start power sooner....what are tour thoughts on this?
Old Apr 28, 2011 | 07:22 PM
bww3588's Avatar
in for this too....
i have an MS4 and looking to install LS3 heads on a 370. wondering if i should advance the cam to take full advantage of the LS3 heads.
Old Apr 29, 2011 | 12:35 AM
Originally Posted by bww3588
in for this too....
Hey bro I found on the search that if you advance it you might have PTV clearance...
Old Apr 29, 2011 | 08:21 AM
bww3588's Avatar
I'm aware of ptv issues, and I compensated for that. I put together parts and machining to put my pistons .002 in the hole rather than out like most ls engines. Also I have valve releifs in the pistons.
Old Apr 29, 2011 | 11:29 AM
[QUOTE=bww3588;14848228]I'm aware of ptv issues, and I compensated for that. I put together parts and machining to put my pistons .002 in the hole rather than out like most ls engines. Also I have valve releifs in the pistons.[/QUOTE
you should be good than with the valve reliefs but i'm no expert...good luck
Old Apr 29, 2011 | 11:35 AM
bww3588's Avatar
I wasent trying to be a dick and you have a valid concern and I thank you. My main question is if I advance it 4 deg. To bring power in sooner, how will the ls3 heads respond to that. If I had cathedral port heads there would be no question, but I know the ms4 and ls3 heads aren't the best combination because of the smaller split on the cam. So I'm wondering if I advance it a little, would that help the cam and heads work a little better with one another.
Old Apr 29, 2011 | 11:39 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
What lobe separation is the cam on? We have advance ground into the cam, on a 112 it has 2 degrees of advance already. Typically we recommend installing them straight up, but we always recommend using a degree wheel if you have it on the cam.
Old Apr 29, 2011 | 11:50 AM
bww3588's Avatar
If your talking to me jon, I have the ms4 on a 111lsa. With ls3 heads.
Old Apr 29, 2011 | 09:11 PM
I didn't take it like that bro...no worries
Old Apr 29, 2011 | 09:17 PM
Thanks for the response John. I called earlier and spoke with Matt and he said just leave straight up. I have a 113 LSA
Old Apr 29, 2011 | 11:11 PM
garygnu's Avatar
the torquer v2 cam peaks sooner then the torquer v3.I would install it straight up.do you have a after market adjustable timing set?
Old Apr 30, 2011 | 04:26 PM
intenseblue's Avatar
Same peak
Old Apr 30, 2011 | 08:42 PM
yeah...its a double roller that can be adjusted by removing the key at behind the oil pump...at least thats how I think it works.
Old May 2, 2011 | 04:49 AM
chrisfrost's Avatar
Depends what You plan on doing with engine/car , but if it were me I would advance at least 2 deg's . The more low end tq. the better .
Old May 5, 2011 | 01:18 AM
Thanks man...I spoke with Matt from TSP and he said its got 2 ground in it depending on the seperation, so I'm going to leave it straight up...plus I read on here that if you have a 4k stall you could get away with keeping straight up. so that's were I'm at.
