Patriot Gold dual valvesprings good? Anybody have them and measure installed height?
#41
LS1Tech Premium Sponsor
Even as few as we have to deal with and install for customers now, I've seen more than 5 in the past year.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#43
If you don't have enough installed height you either machine the pockets to get the height, run a longer valve, or switch spring kits (retainers specifically).
__________________
#44
Old thread, but still good info. patriots look pretty good to me. https://ls1tech.com/forums/generatio...t-results.html
And people used to run .651 lift cams on .650 patriots and they held up. I think with your little lift you should be FINE
#45
I wouldn't throw their kit into the same ring as the 921's (and I'm sure many other reputable sponsors here would agree)! Pressure tests are one thing, retainer machining consistency/accuracy and spring-life are quite another!
__________________
