What kind of compression?
Old Feb 27, 2003 | 01:18 PM
ProTour69's Avatar
Default Re: What kind of compression?
I want to try and stick with all GM stuff since I Want to use the computer from a 2003 Z06 for this application..is there any way to lower compression to 9.5:1 or 9.3:1 with other mods on this car with just the LS6 heads cam and intake...what do LS6 guys do for twin turbo??
Old Feb 27, 2003 | 01:19 PM
ProTour69's Avatar
Also the car will not be forced induction from the start it will be all motor for about 6-8 months that's why I want to stick with the LS6 stuff so its beneficial for me now and when I go twin turbo...Couldn't I just change pistons or something to see lower compression...or get non -ported LS6 heads..please any info is greatly appreciated..I'm lost on what to do!!
Thanks again,
Ralph
<small>[ February 27, 2003, 01:22 PM: Message edited by: ProTour69 ]</small>
Old Feb 27, 2003 | 01:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can IMO inefficiently lower the compression by getting a lower compression piston, or you can get a set of 6.0 heads that have 70cc combustion chambers. Stock LS6 heads are 64cc's.
Old Feb 27, 2003 | 01:24 PM
ProTour69's Avatar
Would the LS6 Cam and intake work well with regular (non ported) 6.0l heads and will the computer from an 03 Z06 be able to be used or will I need custom tuning?
Thanks again!
Ralph
Old Feb 27, 2003 | 02:08 PM
ProTour69's Avatar
What if I used the LS6 heads cam and intake with Diamond Pistons designed to make 9.5:1 compression with a 64cc combustion chamber..would that work well?
Old Feb 28, 2003 | 12:23 AM
ProTour69's Avatar
Default What kind of compression?
Will I see with a set of ported LS6 heads from Scoggin Dickey the LS6 intake and LS6 Cam??
Where will that putme compression wise?
Thanks in advance,
Ralph
Old Feb 28, 2003 | 12:37 AM
annil8r's Avatar
If they havent been shaved it will put u at 10.80:1 but for the price u can get absolute speed stage two heads and a used tr224 cam and make alot more power jmo.
