243 Head on the new 4.8L is the same as the ls6 head
Old May 2, 2011 | 11:46 PM
dnkynrbk's Avatar
Default 243 Head on the new 4.8L is the same as the ls6 head
Found a set of 243 heads at a salvage yard off a 2010 full size chevy pickup it has 243 head casting. the motor looks just like a 5.3l
So are these the same casting heads as the ls6 or different
Old May 3, 2011 | 12:17 AM
matrixiskool's Avatar
If it says 243 then theres no reason it wouldn't be the same casting except I doubt it has the better intake valves in it.
Old May 3, 2011 | 06:27 AM
dnkynrbk's Avatar
i would like to know
Old May 3, 2011 | 06:43 AM
c0ncEpT's Avatar
Same as any other 243 other than the sodium/hollow valves.
Old May 25, 2012 | 05:02 PM
Wagonbacker9's Avatar
The 243s that came on GTOs do not have the sodium filled valves, so it could be either.
Old May 25, 2012 | 05:04 PM
parks450's Avatar
It doesn't have the good valves, they stopped making them. It's a set of 243 heads, same as any other casting 243.
Old May 25, 2012 | 07:37 PM
PREDATOR-Z's Avatar
The way most guys here setup their valvetrain, having lighter valves matter little. Stock 2.00/1.55 stainless valves will do the job just fine if VJ is on the money.
Old May 26, 2012 | 05:55 AM
baxsom's Avatar
243/799 same casting. Only the 243s from an 02-04 Z06 got the lighter valves.
Old May 26, 2012 | 10:18 AM
dodson55's Avatar
and the 04-05 ctsv
Old May 28, 2012 | 01:17 AM
1bad03snake's Avatar
I have 243's on my 2010 5.3L
