What camshaft is the best to make around 390-410 rwhp?
If all you want are numbers,make sure you go to a dyno jet. Numbers really mean nothing. My first set up was dynoed a 424hp 407tq and my car only ran 12.2 in the 1/4mi. The same set up on another dynojet had it at 395hp 380tq. This made more sence. I have had seven cams in my car. A good performing cam that is not to crazy,sounds tough,makes power and will drive well on the streets a 228/232. If you choose to go bigger,it will make more power and the tuner has to work a lil more. The best cam i ever had in a ls1 was the LG Motorsports G5X3 cam. Not sure if you want to run a cam of this size,not the biggest,but was the best in my car.
