Can a LQ4 Block be Dry Sleeved out to 4.125 Bore?!?
Just like the title says can a 6.0 iron block be bored and sleeved out to a 4.125 Bore, Does anyone know a company that will do this?
ERL only deals w newer Alum blocks w the window in it I think
Trying to bore an LQ4 block that far, the sleeves will have to be exposed to coolant. You'd have practically none of the original cylinder walls left.
If this is drag-race-only, you could to a tall fill with block filler, then just bore it to 4.125", forget sleeves entirely.
If you want the sleeves not exposed to the water jackets, then there's no point in using the sleeves.
4.060" is safe. You're only giving up 14 cubic inches at most, assuming a 4" stroke.
Otherwise, just start with an L92 / LS3 block, those can take a 4.125" bore in their stock sleeves.
