Ls1 rod length explanation
Guys please someone help!!! I have a alloy ls1 it requires a rebuild and I can't make sense of the con rod sizing? I think mine being standard are 6.098 but if I want H beam they come in 6.100 or 6.125? Will these be fine with a normal crank? And standard pistons??? Or do I need shorter pistons to accomidate there extra length? If so how much shorter and is the pin size different on these rods? I need new rods as I spun 4 big ends but pistons seem fine I just want it standard but stronger. Cheers guys!
With this combo, you can either use a .040" head gasket without surfacing the block to get .040" quench, or you can use inexpensive GM MLS gaskets with roughly .052" compressed thickness and surface the deck of the block to tighten up the quench.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
