5.3 oil pressure "crazy"
Vic jr,3500 stall
10w40 oil with delco filter
Oil pressure reading pulled from above filter has a mechanicle gauge
Added a quart of lucas and made this issue worse
Cold start takes 10-15 seconds to move the gauge and goes to 20psi stays there untill engine temp gets to 160 then jumps to 35 at a 950rpm idle rpm has no effect untill it gets to 195* then I have 37-38 psi at idle and 65-70 at 3k+
Lifters randomly 'tick' also
Never seen oil pressure get higher when hot what's up guys?
I was all freaked out with my 84,000 mile LQ4 when I fired it up. idle PSI was 20, PSI at 4000 was 30.
Then I realized my mechanical oil pressure gauge was a royal POS.
Have you checked the scanner to see what the oil pressure sensor is reading, or are you carbed?
Interesting about the filter ill keep that in mind
I did use a differant filter this time along with the 5w30 the 'cooler' temp oil pressure is a lot bettter and rises faster but i haven't gotten to cold start it yet and I will update then
