Newb Questions about Ls1
Im not just going to go buy a car, then research it, and realize its more a pain in the *** to get it to where i want it to be then i imagined. Thats completely retarded and a *** backwards way of doing things. I am not just going to buy off impulse, thats a 16 yr old thing to do. The "oh, i want it, im buying it now" attitude doesnt cut out, id like to make sure ik what to do with the car before i buy it so i can make it last when i do begin to mod. If i remember correctly, that is the right way of doing things. Research, then buy. Please correct me if you think im wrong.
No you don't need to port your heads for the ms3 or 4 cam, but they do like alittle higher compression (11-11.5:1) if your plan is to go forced induction in the near future i'd get the heads ported....if your going to wait a while I'd look at getting them milled too.
Without milling the heads it will be alittle more sluggish, but you don't want that high compression with forced induction.
Porting the heads will give you gains both ways...better n/a flow, and once you go FI you can move more air easier and make more power with lower boost psi.
I didn't know you could pick your lsa on the Ms cams...the 115lsa would be your best choice of them. You will also want to check your PTV clearance....maybe just go with a small dish and valve reliefs so you can get plenty of room and lower your compression for boost
thanks for the info man. there is alot more that i gotta do to run lopey cams then i thought with the ls1s...
http://www.youtube.com/watch?v=39wH6RnrbVk
^ I LOVE THAT!
yea i talked to Texas Speed and they told me i need oil pump as well.
Id be doing this: http://www.texas-speed.com/p-1158-te...pring-kit.aspx
and this: http://www.texas-speed.com/p-653-rol...iming-set.aspx
this: http://www.texas-speed.com/p-784-arp...04-blocks.aspx
this: http://www.texas-speed.com/p-194-del...asket-kit.aspx
this: http://www.texas-speed.com/p-1941-sl...eavy-duty.aspx
Im not sure what pistons and rods i should get so i can get myself between 600 - 650 rwhp.
All the Stang-boi profanity and abbreviations don't even rise to the level of 16 year-old behavior. Grow up.
If the fact that i own a Ford and that I'm researching a car before jumping into buying and pouring money into it offends you, Move on. Because if you don't have any useful information to share with me, you're completely useless to me and i could care less what you have to say.
