ms4 and 3200 stall
Old Jul 6, 2011 | 12:14 PM
blocc monster's Avatar
Default ms4 and 3200 stall
Hey guys my buddy just got a 2002 ss with a ms4 and 3200 stall. How much et is he missing? How better would a 4k stall run i said .2 .3 wat do yall think?
Old Jul 6, 2011 | 01:03 PM
MYSTIC-1SC's Avatar
Hard to tell exactly how much e.t. you will pick up by swapping to something in the 4000 range, but you are definetly leaving a lot on the table only running a 3200 converter with the MS4. How does the car 60ft currently?
Old Jul 6, 2011 | 01:10 PM
Big&Tasty TA's Avatar
Like MYSTIC-1C said, its hard to know how much the new converter will pick up, but there will be a noticeable gain because a 3200 is a tad small for the MS4.
Originally Posted by MYSTIC-1SC
Hard to tell exactly how much e.t. youll pick up, but you are definetly leaving a lot on the table only running a 3200 converter with the MS4. How does the car 60ft?
the car is cuttin 1.74
Old Jul 6, 2011 | 01:14 PM
I told him he needs a 3600, does that sound bout right?
Old Jul 6, 2011 | 01:35 PM
MYSTIC-1SC's Avatar
Personally I would go with something in the 4000 range.
Old Jul 6, 2011 | 01:54 PM
farmington's Avatar
IMO if he's already cutting a 1.74 short time, he's not that far off, plus the lower stall will be easier on the rearend if he still has a 10 bolt.
Old Jul 6, 2011 | 02:07 PM
Jon@Texas-Speed's Avatar
The higher stall speed will get him further into the powerband of the cam. It will only improve it. The higher the stall the better but you have to balance that between track duty and street duty. I would go 3600 minimum if it were me. I think closer to the 4000 mark would be better but some guys don't like that much converter on the street.
Jon
Old Jul 6, 2011 | 05:30 PM
PREDATOR-Z's Avatar
Yank SS 4000
Old Jul 6, 2011 | 07:59 PM
01ssreda4's Avatar
^^^Agreed...
Old Jul 6, 2011 | 08:12 PM
SOMbitch's Avatar
I like my Yank SS3600 since I am mostly street but have seen the SS4k stall be worth 2+ tenths 1/4 on MS4 cars that can put it to the ground.....
Old Jul 6, 2011 | 08:22 PM
Mazzenger's Avatar
I went from a 3500 to a 4000 stall with an MS3 cam. There was a big difference in the seat of the pants feel. I don't know how much time it cut at the track though. Also 3:73 gears made a big difference in how the car felt.
Old Jul 6, 2011 | 09:01 PM
ramairracer's Avatar
pt4400 and bitch will cut 1.5x 60fts like me
Old Jul 6, 2011 | 11:43 PM
z99ls1's Avatar
Restricted User
Im sure it would be worth it. I would guess .3-.4 reduction in et with a 4k over 3200
Old Jul 6, 2011 | 11:48 PM
garygnu's Avatar
more stall and DRs.and get better suspension parts.
Old Jul 6, 2011 | 11:51 PM
silverz28camaro's Avatar
if he goes with a ss4000 stall and has traction, I would bet .4 would be seen
I had a 2800 in my 224 cammed car and I felt it wasn't enough converter, I swapped for a vig.3600 and spun to a faster time. 11.7 vs 11.5 spinning slightly
Old Jul 7, 2011 | 12:12 PM
Thanks guys!!!!!!!!!
