Stoped making LS1 Timing dampander
Old Jul 12, 2011 | 02:22 PM
3rdCoastPowerSports's Avatar
Default Stoped making LS1 Timing dampander
Why did they stop making the LS1 timing chain dampaner?????
the timing chain dampander keeps you from snapping your chain right?
i have a ProGear adjust timing set do i need the dampander?
Old Jul 12, 2011 | 04:24 PM
vettenuts's Avatar
Katech had a few left, check with them.
Old Jul 12, 2011 | 06:39 PM
i will check with them... but i was more curious why they stoped producing the LS1 dampner,,,, was there a designe flaw with it? what were the OE dampaners made of
Old Jul 12, 2011 | 07:20 PM
vettenuts's Avatar
There wasn't a lot of demand and the price was high (over $100) because they were not mass produced like the LS2 damper, which doesn't fit the LS1 block.
Old Jul 12, 2011 | 07:30 PM
01ssreda4's Avatar
Is the LS6 (pre-drilled for it) using the same TC damper as the LS1? And are all LS6 blocks pre-drilled. Just curious.
Old Jul 12, 2011 | 08:43 PM
CraigS's Avatar
My 01 LS6 was drilled for the smaller LS1 damper
Old Jul 12, 2011 | 08:45 PM
vettenuts's Avatar
My 02 LS1 was pre-drilled but it also the LS6 block.
Old Jul 13, 2011 | 11:49 AM
cwalsh's Avatar
My 04 LS6 block in my coupe is drilled for one
Chris
Old Jul 13, 2011 | 03:03 PM
joecar's Avatar
My concern with the LS1/LS6 TC damper is how strong is it, has anyone ever known the plastic to break/chip/fragment or otherwise fly apart...?
Old Jul 13, 2011 | 03:57 PM
what is the LS2 dampner made of?
Old Jul 14, 2011 | 04:04 AM
vettenuts's Avatar
Its more of a Nylon type material and seems pretty rugged. Lifter trays are also non-metallic.
