Anyone ever break a timing chain doing this?
And just while cranking it over the timing chain broke.I never even heard of this happen to anyone while just tring to start it.
My car never ran,just cranked a few times then broke the chain.
I also did the a ls6 oil pump and inspected the chain then and everthing looked fine.Chain was stock and had only 20,000 miles on it.
Any thoughts as to what caused this?
Thanks
mark
Also check for damage, broken chain = open valves. Open valves + pistons = not good
Chuck
And yes it was dot to dot meaning i put it where the top gear had the dot on the bottom of the gear and the bottom gear had the dot on the top of the gear.
Cranked it over once by had to make sure it stayed dot to dot.Only thing that did seem kinda odd was that when i first tried to crank it over by hand it seemed really hard to do(sorta like a bind).And that was with the heads off the car.So I took the timing chain and top gear back off and checked everything.It looked ok so I put it back on and it turned over fine(normal)
I have no clue what that was all about.
I know its time for a double roller,but the heads have to come back off now to see if I have bent valves(which i probally do) and whatever else that might be wrong.The heads arn't milled and I'm using the Futral Motorsports F6 on a 112 which isn't big enough I don't think to even worry about clearance issues.
I just don't want to throw another chain on there for it to do the same thing.It just don't seem right that it broke while tring to crank it over.
Hey Beast
How would I know by looking at the gears if it was 180 out?I mean I put the top gear back on the same way it came off without ever turning the motor over.
pics soon to come!
Nice4thgenz - FYI there is nothing that you can do when grinding a cam that will cause this problem. But we are going to check it out.
As I said in my PM to you.
I just put the stock cam back in the car and everything spins freely like it should.I also have a C1 hammer cam that was in the car before when it was cam only and it was fine of course.
So that leads me to believe that something is wrong with the cam.I'm glad your looking into this,and I thank you for that.Hope to figure out what's wrong with the cam soon as you get it.
Thanks
Mark
FYI I'm not in the cam manufacturing business so I wouldn't know
It would spin over with the 3 bolts in finger tight, but once tightened it would not move at all. I've done 3 cam swaps on my car and I've never had a problem like this.
As Slick stated he never had a problem with his C1 cam and even put the stock cam back in and it spins over. So it seems to be a problem with the cam itself.
Soon as Allen gets the cam back we should know what the problem is or what happen.
Futral Motorsports customer service is top notch thus far,and is doing everything he can to take care of this problem. Thanks Allen
Its just one of those things,it happens
