High rpm crankcase pressure = oil pan leak
#41
Well, new lower gasket & vent on driver side valve cover & clamp on pcv hose at the TB.
Still leaks, it appears the UPPER pan gasket FRONT so will pull all the front suspension & put that in next.
Main seal & the rest of the front engine cover do not show leakage.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#46
Designed for a wide variety of GM engines for sub freezing condition where the pcv valve freezes (moisture in the crankcase fumes) and the crankcase cannot vent as normal thus resulting in oil leaks from the engine.
http://www.ls1gto.com/forums/archive...p/t-60187.html
If you read this thread a little spykesta posts a couple of tsb's.
I figure it may help with my leak at high rpms.
I'm gonna do a leak down test as soon as I have the chance, but I think I just have a high rpm pressure issue. There is ZERO leak at normal easy street driving, for hundreds of miles.
#47
Update
Ran an autox event yesterday and 2 parts of the course were fast enough to be on the (2nd gear) rev limiter briefly and for 3 runs back to back so I consider this a good test, the leak area was cleaned & dye still in.
The "fixes" so far are:
1) breather on dr side rear rocker cover (did not help per previous test)
2) GM venting oil filler cap (not previously tested)
3) I lowered the oil level to full (top of hatch section - not previously tested)
Result was bone dry, no leak whatsoever.
Conclusion is either the venting filler cap or lower oil level or both eliminated the issue.
I will no longer overfill for autox & it probably was never needed as duration & quick l/r moves probably do not trap oil or if they do it's brief & not going to drop the oil pressure, maybe.
Next DE I'll overfill 1/2 qt only & monitor the oil press & see how it goes & will post back here, but it could be a few weeks.
Meanwhile, when I get a chance I'll do the leak down & post that.
Thanks all for great posts.
BTW no codes & engine runs strong as ever so I don't see that there is any vacuum leak issue with what I have done.
#48
Upate:
Ran a DE 6 20 min sessions & leak is back. Waiting on an extended warranty inspection to approve replacement of front cover gasket, upper pan gasket, crank pully seal etc.
About 12 hrs labor.
GMPP approved for repair, in the shop.
About 12 hrs labor.
#49
Update:
New front cover, both oil pan covers & main seal.
Still leaks, appears dry at main seal, leak where front cover & upper oil pan come together.
Is this some extremely hard area to fix a leak at?
Is there some trick that FSM does not specify?
Arrrg.
Arrrg.
#51
There is an alignment tool for the front/rear covers and oil pan. I've never used it and mine have never leaked at the junctions. I do exercise common sense when putting an engine together though. I installed one of those caps. Oil mist on my newly painted coil packs grrrr.
#52
I have not got any evidence of any oil/pressure/mist coming out of the cap.
#53
Shop pulled the suspension & redid the upper pan gasket/sealant. He will drive it a couple of days (maybe 50 miles) & ck for leak. I would rather he do this than me have to bring the car back again & arrange for another driver for drop off/pick up.
Sheesh
If I had a damn life I would have done this myself.
What a pain.
Hope it stays dry.
Sheesh
What a pain.
Hope it stays dry.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#55
Dry so far, oh he didn't torque the lower steering shaft to steering rack clamp bolt so my steering got all hinky until I torqued it. Rechecked all the sub frame & steering rack & suspension bolts & witness marked them.
Sigh.
Sigh.
