NEW! KATECH High capacity LS oil pump
New for 2011 Katech has added another oil pump to it's lineup. The new pump has 23% more capacity than the KAT-A2390 pump. Like the previous pump, it is also blueprinted and CNC-ported.
-Brand new G-Rotor oil pump
-23% more capacity
-CNC-ported oil inlet
-Strict procedures which assure ultimate quality
-Includes heavy duty oil pickup tube o-ring
In stock now! Order online http://store.katechengines.com/high-...pump-p272.aspx
Do you have any test data, etc that could tell me ....
What's the oil volume vs. RPM curve look like on the stock pump versus these hi-performance pumps?
Also, what is the stock oil pump relief pressure setting and the relief pressure setting on these hi-performance pumps?
Yes.
According to Scoggin-Dickey Parts web site, the GM standard LS oil pump relief valve is set to 32 lbs. Here's a copy of their item listing:
LS Engine Oil Pump
Part Number: 12586665
Brand: GM Factory Replacement Parts
SKU: 12586665
Price: $94.85
Standard volume GM oil pump for LS engines. Original equipment oil pump for the LS1, LS6, LS2, and LS3 engines. This pump is used on most current V8 LS engines that are not equipped with Active Fuel Management.
Technical Notes:
Standard Volume LS Oil Pump
By-Pass Spring Opens at 32-psi
Recommended Pump for Most LS Engines
LS Engine Oil Pump
SKU: 12586665
Price: $94.85
Technical Notes:
The following users liked this post:
53te39 (04-16-2021)
Humm ... 32 psi seems low since I see 70~75 psi on the oil pressure gauge at high RPM on my stock LS6. Maybe that is when it just starts to crack open, but regulates max oil pressure to around 75 psi (?).
High volume oil pumps are useful for engines that require more volume (not necessarily with more pressure) - maybe due to adding a turbo that has oiling needs, etc. The only way to get more high RPM volume on a stock oiling system is to increase the relief pressure along with a higher volume pump. Higher volume pumps also give you more volume and pressure between idle and the pressure relief point at higher RPM ... but once the pump hits pressure relief, then that will determine the actual volume of oil going down the engine's oiling circuit no matter how big the oil pump is.
ARE has LS1/LS6 dry sump pans. Scavenge pumps mount where the AC compressor goes and is driven by the same belt. The pressure pump in the engine stays. Also a dry sump tank would need to be mounted. On our LS7 F-body we built years ago we put the tank where the battery was and relocated the battery to the back.
