highest compression on pump gas
Old Jul 27, 2011 | 09:20 AM
slt200mph's Avatar
My heads are milled down to 59cc chambers and I use a .040 Cometic head gaskets for a nice tight quench. Compression is 11.4-11.5 and with a proper tune it runs great. As sorry as the gasoline is getting now days that is about as high as I want to go on a street car. High Compression is free HP/TQ..
Old Jul 27, 2011 | 10:21 AM
703 CAMAROSS's Avatar
Iv been talking to tsp about rotating assemblies but never mentioned compression. I think Il send a pm
Old Jul 27, 2011 | 02:50 PM
Frost's Avatar
Originally Posted by mark21742
Static compression is just your total volume difference of the cylinder and chamber at bottom dead center and top dead center. But dynamic compression adds the cam into the equation....you can't start building pressure til both intake and exhaust valves are closed
This!
Old Jul 29, 2011 | 10:30 AM
Edrummr's Avatar
FWIW, I'm running 8.65:1 DCR, stock 243 heads, .040 gaskets, LS1 block, elevation: 1000 ft, no detonation/retard.
Old Jul 29, 2011 | 10:13 PM
NHRAFORMULA00's Avatar
If you have a rotating asembly out of the block and are gonna run near 12 to 1. Open the ring end gaps up a little to like .025 from stock.This keeps the ring land from breaking when the rings run out of clearance due to too much heat and or detonation.This will help it survive if the tune is spot on.
Old Jul 30, 2011 | 03:42 PM
Chicken Coupe's Avatar
Originally Posted by 703 CAMAROSS
It's all starting to make since now. Maybe Il just buy dynomation 5 and build my engine on the computer before I buy all the parts. I could still buy my rotating assembly because I could just change the cc on the heads if needed to raise or lower compression. So maybe Il do that. Anyone else have experience with dynomation 5?
Your pistons and rod lengths make a big difference also. I would not buy nothing, except maybe a crank if I knew I was not going to stroke it. You can play around with rod length to your compression height of your pistons to change CR'S. You have deck height and all that stuff to consider. And there right, It's all about the tune also. Lot of factors to think about. I am runnin a LQ4 block which is a 9.230 deck with flat top pistons with Patriot 59cc head and .051 gaskets with no problems. Pistons come up above deck .008. Just remember- stroke divided by 2 plus rod length plus compression height gives you total height. You can play around with different pistons to get different results.
Old Jul 30, 2011 | 08:19 PM
mark21742's Avatar
I already had the crank and rods and heads, so THIS is why it took me a month to finally pick my cam and then pistons
Old Jul 30, 2011 | 08:26 PM
Sounds like me; took me sometime too. Good luck on your build...
Old Jul 30, 2011 | 08:40 PM
This is confusing lol
Old Jul 30, 2011 | 08:45 PM
Can anyone tell me a formula to figure out dynamic compression? I read the page from the link twice and it didn't out right tell u the formula to figure it out. Can some one help me lol
Old Jul 30, 2011 | 09:14 PM
mark21742's Avatar
Try this
http://www.wallaceracing.com/dynamic-cr.php
Old Jul 30, 2011 | 09:36 PM
  #32
I tried that and I'm lost lol Im just going to keep trying to figure all this out some how
Old Jul 30, 2011 | 09:40 PM
  #33
speedtigger's Avatar
Old School Heavy
It can be if you go too far into the rabbit hole. You can end up with over analysis paralysis.
You can avoid the rabbit hole by just using fellow racers practical experience. With that being said, here is mine: I have 10.9:1 static, 8.4 dynamic with a smallish 224 camshaft and I run 93 pump gas at sea level in serious Florida summer heat with no problems.
If you are the theoretical type, I will go against the grain here and tell you that dynamic compression is one factor but more important is volumetric efficiency. All of these dynamic compression ratio calculators that people use are using a generate a figure that will have more to do with a cranking compression test than an actual running engine. For this reason, I don't put a lot of stock in the generic dynamic compression calculators. So, I can see using it as a general guide, but certainly not the definitive science that some people think it is.
This is why I like the fellow racers practical experience approach. There are tons of guys on here with working combinations along with a slew of vendors with tons of practical experience. I bet you can come up with a proven combo without too much "engineering".
Old Jul 30, 2011 | 10:02 PM
  #34
If only there were others with 383 that puts down 500-550 na so I could just use there setup. I figure if you can get 500 out of a 347, you can get 550 out of a 383
Old Jul 30, 2011 | 10:19 PM
  #35
Old School Heavy
550 out of a 383 n/a is absolutely possible. Whether or not it is doable with pump gas is a good question. If Patrick got to 500, it surely would be worth while to study that build thread.
Old Jul 30, 2011 | 10:34 PM
  #36
JS01's Avatar
Originally Posted by JS01
11.25:1 if the engine is actually worth a **** (making good VE). If not you could go higher.
x100000000
