Thinking my bird has a broken wing :(
Old Jul 28, 2011 | 07:08 PM
GTOdave's Avatar
Default Thinking my bird has a broken wing :(
well i noticed today that my engine is making the sewing machine noise again..like when one first starts up after a cam swap..i not too sure what it is..just noticed it today after work..but im thinking it could only be a bent pushrod or something beacuse she still ***** and gets like a raped ape...im not too sure though..any suggestions people? oor should i just sell the engine how she is and dump an LS2 in her??
Old Jul 28, 2011 | 09:22 PM
FORD KILLER's Avatar
Maybe have someone check it out alittle closer. It may not be any big deal. The LS2 would be nice though.
Old Jul 28, 2011 | 09:40 PM
garygnu's Avatar
check for bent push rods or broken springs.how many miles on the current motor?
Old Jul 29, 2011 | 10:06 PM
LilJayV10's Avatar
I wouldn't jump to replacing the engine just yet. Unless you are just looking for a reason.
Old Jul 30, 2011 | 11:12 AM
Cape T/A's Avatar
did you over rev the the engine, if not i doubt its a bent push rod. They dont bend from everyday driving. By the way, I have yet to hear a cammed ls1 that doesnt make noises.
Old Jul 31, 2011 | 08:17 PM
GTOdave's Avatar
well i stated it the other day and the ticking/ knocking is louder..don't think its a bent push rod because its not miss firing or anything . and its coming from the top end..taking it apart this week to see what the deal is..think it may be a lifter..has comp R lifters in it.......i think comp r lifters are junk.
never over rev it..i speed shift at about 6900 rpms 102xxx miles on it...and only put 20xxx sense cam.
Old Jul 31, 2011 | 08:21 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I'd stop beating on it until you tear into it a bit. Be it a broken spring, bent pushrod, bent valve, etc these things typically don't end well when they get hammered on after the problem starts.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 31, 2011 | 09:58 PM
LilJayV10's Avatar
The comp R's require a different preload than OE lifters. But if you have been driving it for a while and it just started I doubt it's that.
Old Aug 1, 2011 | 05:36 PM
GTOdave's Avatar
i haven't started the car sense it made that noise..trailer-ed her home and going to start into it tom. night.
but i have a set of LS7 lifters i bought from awhile ago im going to use if that's the problem..but regardless im going to need head gaskets and some head bolts, what kind of numbers could you get me at Texas speed for those Matt? ive bout some head cam kits from there and all my aftermarket parts have cam from there..
Old Aug 1, 2011 | 05:38 PM
GTOdave's Avatar
i don't know what else it could be..the engine is not miss firing what so ever and the noise/knock is coming from the middle right under the intake manifold it sounds like..i just need to et the thing apart and see what it is.
Old Aug 1, 2011 | 10:57 PM
LilJayV10's Avatar
Start simple. Take the valve covers off and look at the rockers and springs. Then dive a little deeper. Take the rockers off, check the tips, check for bent push rods.
It's tough to tell sometimes if its a knock or a tick.
What is your setup? What cam, heads, pushrods, springs, etc.
That will give us a little more background on your setup that may help people figure out what's going on.
Old Aug 2, 2011 | 05:17 PM
GTOdave's Avatar
Ok well i have a custom comp cam..spec myself..238/242 lift is 605/ 610 on a 112+2 lsa , with comp R lifters, ported ls6 oil pump, trick flow 7.400 hardend push rods and ported intake and throttle body..that's it stock rockers and etc..
Old Aug 2, 2011 | 07:51 PM
LilJayV10's Avatar
Has your oil pressure dropped any or is it the same?
Old Aug 3, 2011 | 07:11 AM
GTOdave's Avatar
Oil pressure has not dropped any..completly fine.
Old Aug 3, 2011 | 09:42 PM
SOMbitch's Avatar
Could be a stock rocker puking needle bearings or a rocker nut backing off....
Old Aug 3, 2011 | 09:50 PM
Monzsta's Avatar
When my oil pump o ring died the lifters got noisy, but I still had oil pressure. The lifters couldn't deal with the air getting injested with the oil.
Fyi, 3 o-rings work so nice on the tube. They bottom out with about 1/2 an o-ring's width so the whole stack gets lightly compressed, which ensures a leak proof seal forever. Dropping the pan flat sucks, though.
Old Aug 4, 2011 | 05:19 AM
GTOdave's Avatar
Well took her apart last night when I went to drain oil before I took her a part found a neddle bearing attached to my oil plug..soo I think I found the problem ha time for some new lifters I guess.
GTOdave's Avatar
Some new rockers I mean ha
Old Aug 4, 2011 | 07:12 AM
crainholio's Avatar
Good find, inspect the valve springs closely while you're doing the rocker swap and verify none are broken.
There has been a lot of discussion about the GM rockers being limited to 0.55x" lift at the valve due to their design. With your lift, you might want to do some research before picking your rocker path.
Old Aug 4, 2011 | 08:46 AM
aAZz's Avatar
Good find
