Darth Vader....Your LSx Stroker is ready!!
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I'm wondering how those running rectangle ports will react to to all this...
Gas ports....yep....not conventional for a "street" motor but I'm of the opinion that the ring material I selected and the ductile iron sleeve (much stouter and more durable than a factory gray cast sleeve) will hold up just fine in the 10,000 miles I would be lucky to drive this car before yanking the engine and building something else (that's three years of driving for me....LOL). This was one of those moves that I was willing to try on my own build....and with the lighter weight ring package I selected one I feel will work out well in contributing a little extra power to the bottom line. This motor will make more than an average build that looks the same quickly on paper because I went after all the nickel and dimes....at the end of the day they add up and you have an extra 50 cents in your pocket and a car that runs a few tenth quicker than it ought to.
Someone asked about the block.....yes....its a 6.0 liter aluminum LS2 block that I had Steve at R&D install Darton dry sleeves into. He did a great job of course....this guy is simply the source for work like that. And the combination is in fact a 4.185 bore X 4.125 stroke. The sleeve is longer than a stock length sleeve better supporting the piston at the bottom of the bore (less piston rock in spite of the extra stroke). In fact my 4.125 stroke hangs the pistons less out the hole than a stock LS2/LS3 block with a 4" arm....and thats bonus IMO.
What else.....coils.....yep....they are MSD's, not painted OEM coils.....the size gives them away. I had to do alot of grinding and modifying on the factory coil brackets to get these to fit. I was under the impression these were a bolt on but truthfully I never read the instructions....LOL Anyway, they look great and might potentially be worth a few ponies as well at this level....if I have some time I may back to back them against my stock coils.
-Tony
PS....With my 75 cc heads and an .040 gasket this combo nets exactly 11.75 to 1.....aggressive for a 91 octane build but I suspect with the overlap and the cam installed position I will likely settle on, I may have a low enough DCR to run 91 all day long (92 or 93 octane would be a no brainer here). Worst case if I get a little knock retard I may opt for a Snow Performance N/A methanol injection kit, but I really feel I'm going to pull this off on straight 91 octane. Once again for a customer I would probably opt for something slightly more conservative (not much....like 11.5 - 11.6!)
