Darth Vader....Your LSx Stroker is ready!!
Old Aug 3, 2011 | 04:14 PM
  #41
CHEVYMAN434's Avatar
Default ..........
Looks like what i need..
Old Aug 3, 2011 | 05:08 PM
  #42
KRAZY K 2000 TA's Avatar
Tony what did you paint the intake with?Paint brand and method?
Old Aug 3, 2011 | 06:55 PM
  #43
VIPRETR2's Avatar
I thought they were MSD coils but almost everything I've read on them is negative so I thought I was mistaken. I'm sure you will expose any weaknesses they may have.
Old Aug 3, 2011 | 07:19 PM
  #44
SinisterZ28's Avatar
That engine belongs in a art mag. Nice work, maybe with enough time n hard work I too will have something as nice as that,lol. I'm sure it's going to make great numbers and perform awesome.
Beautiful !
Old Aug 3, 2011 | 09:50 PM
  #45
LS1-NAVY's Avatar
thats sick
Old Aug 3, 2011 | 10:28 PM
  #46
Zmg00camaross's Avatar
Old Aug 3, 2011 | 10:49 PM
  #47
garygnu's Avatar
tuning a high out put in Cali.,go figure.great motor ,I bet it dose great .how much?
Old Aug 3, 2011 | 11:08 PM
  #48
SnIpEz's Avatar
That is the most gorgeous looking engine I have EVER seen...
Old Aug 4, 2011 | 02:11 PM
  #49
brokenfly's Avatar
"tony shoemaker"......
Old Aug 5, 2011 | 07:07 PM
  #50
Tony Mamo @ AFR's Avatar
Flow Wizard
So after literally years in the making I finally had a chance to see the "Vader 454" unleash some of its fury at the Westech dyno facility in Mira Loma, CA (using the same dyno and test cell I use to do all my LS testing for directly comparable results).
It was one of those unforgettable days filled with anticipation and excitement and unfortunately as the day progressed some slight disappointment as well.
Im going to quote myself taking a paragraph from the first post I made to start this thread....
Originally Posted by Tony Mamo @ AFR
I have numerous different tidbits in this build that make it unique and add a bit of the wild card to the equation (wild card as it could be a good move or it could be a bad move....LOL), but at the end of the day personal builds are the ones you can push the envelope a bit and try some things. You can always go back and fix something that may not have worked out as hoped for and have no one to answer to but yourself....if you did hit a homer you could consider including the same in a customers build down the road....if it's a flop you learned something, rectify it and move on.
It's like I subconsciously knew what might transpire on the dyno....LOL
To make a long story short I didn't get a chance to complete all my testing (I had a short list of changes to make in an effort to extract more power from the combination). About a dozen or so pulls into the day we noticed the engine starting to smoke out of the breather at WOT when we loaded it for the pull. After inspecting leak down, cranking compression, spark plugs, and cutting open the oil filter (everything looking like a clean bill of health) I decided to run it a little more....power was exactly the same but it was venting crankcase fumes during the run. I decided better be safe than sorry and halted any further testing till I find out what was going on.....something had obviously changed. My suspicions were a ring had stuck in one of the grooves or I pushed the limit on my piston to head clearance (quench distance) just a bit too much. After taking the engine home yesterday and not wasting a minute to find out it turns out the latter was exactly what transpired. There was some very light piston to head contact on one side of the piston, enough to close up the critical top ring gap not allowing it to conform to the cylinder wall (hence the blowby we started seeing). In fact I was sooooo close to my target (which was to get the piston so close to the head the carbon is almost cleaned off), it took a dozen or so runs to get the rods hot enough to stretch to the point of light contact. And thats how it goes.....sometimes a couple of thousandths is the difference of winning and losing when it comes to high performance engine assembly.
Lets get to the good stuff.....this engine surpassed my highest expectations and did so with the wrong header (still had the baseline 1.75 tube headers) and without the benefit of the vacuum pump or any of the items I planned on testing to hopefully find a few more ponies (rocker ratio swap, moving the cam position around, etc., etc.).
The engine sounded incredible on the dyno and twisted the strain gauge on the SF902 SuperFlow to the tune of 652 ft/lbs of torque and a best of 731 HP!! It was making north of 700 as early as 5700 RPM's and over 640 ft/lbs by 4400 (carrying over 640 all the way to 5800). When we loaded it and started the sweep at 3500 it was already producing 45 more ft/lbs of torque than my 383 made at its peak (about 570) and based on all the previous testing I have done that lead in torque figure will be at least 10-15 ft/lbs higher when I swap to the larger header (1.875 tube)....in fact the larger header will fatten the power and torque curve everywhere in an application like this.
Check out the dyno curve.....it looks like a boosted engine in some respects
And here is the hard data from that run....
Needless to say I'm thrilled with the results and look forward to returning to the dyno (likely next month) to complete the testing and see what this combination still has in it....the larger header is a no brainer and some of the other moves I would like to make may be worth a few as well.
Cheers,
Tony
PS....I will post the results of the second round of testing in the dyno results section of this board when I have all the data.....at this point this is more of a technical related story with some numbers and a pitstop along the way!
Old Aug 5, 2011 | 08:14 PM
  #51
lexva_58's Avatar
Well that the only way to learn right lol
very nice numbers
congrats
Old Aug 5, 2011 | 08:26 PM
  #52
Patrick G's Avatar
LS1 Tech Administrator
Looks like a Kenne Bell 3.3L supercharger got stock on top of your engine Tony. Very broad torque curve and nice power. Should be around 650rwhp once it's in the car which is muy nice.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 5, 2011 | 10:36 PM
  #53
LilJayV10's Avatar
Tony,
What are you going to change so the piston doesn't kiss the cylinder head anymore?
Congrats on the numbers. I'm sure it will keep getting better.
Old Aug 5, 2011 | 10:46 PM
  #54
majorityrls's Avatar
congrats. I could only hope to get a engine like that in the firehawk!
Old Aug 5, 2011 | 11:51 PM
  #55
Flow Wizard
Tony,
Jay,
That's easy....just order a slightly thicker head gasket.
Cometic makes them in varied thickness....I set the quench where I wanted it in the first place based on the pin height of the custom piston I spec'ed and how much material was removed from the block. The original set-up I went with an .040....will probably use an .045 when I put her back together but make no mistake about the fact I knew exactly where I was setting it originally btw....just got a hair too aggressive.....actually more like half a hair if I had to guess!
Bottom line, you push the envelope enough on these optimized builds for max power and stuff like this is inevitable. I was just forthcoming enough to share....I've seen alot of stuff conveniently buried in this industry....featured builds that grenaded right after (or before) the last flash bulb went off....its not all glory and there are lessons to be learned. As I said, I handled numerous aspects of this build slightly differently than I would have had it been a customer's engine.....I was willing to take some calculated risks with my own build and alot of them paid off.
When the smoke clears I would rather have a 740+ HP engine that needs a slight adjustment than a 715 HP engine that doesn't! (which would have still been a huge number thru a cathedral head and a FAST manifold).
Also, now knowing without a doubt the capabilities of what I'm building will make the downtime of getting her back together alot more tolerable!
I cant wait to experience this engine in my C5.....When I was at Westech I compared the overlay of the 454 against the 383 I used to run (from the same dyno) and the comparison of the two curves is retarded.....especially when I consider just how capable and fast the car was with the 83' in it (high tens at 130 traps).
I will try to post that next week in fact.....I need to have Steve at Westech email me the 83' dyno file.
-Tony
Old Aug 6, 2011 | 12:05 AM
  #56
SHovV's Avatar
very awesome build.
Old Aug 6, 2011 | 04:29 AM
  #57
SS_Wannabe's Avatar
love this thing, may not be a good street engine but would love the same look look with some decent streetability. anywhere we can see a parts list, or more pictures?
Old Aug 6, 2011 | 06:10 AM
  #58
02sleeperz28's Avatar
Very nice!
Old Aug 6, 2011 | 08:10 AM
  #59
Stage7's Avatar
Beautiful engine and great results Tony. Thank you for sharing the good with the bad as well. Pretty rare in the industry as you noted.
Should be another 10 or hp with the right headers too. Almost unthinkable with a plastic intake a few years ago. Cubes work...
Old Aug 6, 2011 | 08:34 AM
  #60
2000PewterT/A's Avatar
Beautiful build.
