How is 97-98 different?
Old Mar 3, 2004 | 01:58 AM
98 T/A raptor's Avatar
Default How is 97-98 different?
I have been reading and have seen that the valve covers are different I was wondering if there is anything else that is different.
Old Mar 3, 2004 | 02:31 AM
Scott Turvey's Avatar
Essentially, no. The "perimeter bolt" heads are the biggie. As with every year, there were always slight changes in the ports and/or chamber. The rod bolts and pushrods were troublesome. GM put out a couple of tech bulletins to their dealers about replacing them if there was a problem. They advised to tell people to keep it under 5800 RPM, if I remember correctly. Why? Some rod bolts broke, and bent pushrods were fairly common.
Old Mar 3, 2004 | 02:35 AM
Damian's Avatar
LSX Mechanic
Valve covers
Heads
PCM
Wiring Harness
Coolant Sensor in Driver's head
Bigger Injectors
Bigger Fuel Pump
Guage Cluster
Old Mar 3, 2004 | 02:46 AM
SO will heads off a newer LS1 go on mine? I was gonna get AFR heads if they ever get there act together or will I just have to get different valve covers?
Old Mar 3, 2004 | 04:06 AM
jrp's Avatar
jrp
SN95 Director
all ls1 heads are interchangable. you'll just need accompianing vavle covers and/or coil pack brackets.
click the info link in my sig.
Old Mar 3, 2004 | 04:20 AM
Thanks I was worried for a minute.
Old Mar 3, 2004 | 12:09 PM
Are the perimeter bolts that big of a deal?
Old Mar 3, 2004 | 03:33 PM
JurisAg02's Avatar
I know lots of people with 98 ls1's doing 7K rpms daily for 2-3 years now with NO PROBLEMS or oil consumption issues
Old Mar 3, 2004 | 03:40 PM
98SS Blackattack's Avatar
Yea 98's are faster.....lol
Old Mar 4, 2004 | 01:25 AM
Only if you want stuff like valve covers or spacers.
Old Mar 4, 2004 | 05:03 AM
If I get AFR heads if they ever come out then it wont matter right.
Old Mar 4, 2004 | 05:27 AM
jrp's Avatar
jrp
SN95 Director
just get whatever heads you want the appropriate vavle covers/coil packs :shrug:
