LS engine building. Engine builder told me I couldnt do it.
Is plasti-gauge really that crappy?
Is putting an LS1 together that difficult?
He has me a little worried and a little pissed so im just looking to see what you guys think.
Thanks in advance.
Trey
Plasti-guage does the job just fine if you torque it right and have all the main caps, etc. in the right palce
And an ls1 is a lot different than a carbeurated engine, even tpi for that matter. i have built a 355 and we used plasti- guage on it and it runs great......i do like the idea of putting 3 pieces on each bearing though......but the point is it is gonna be different to build an ls1 (will be my first time to when i can afford it) but the short block will be about the same as the old 350s, but im sure there are prob a few differences especially considering its a distributorless motor lol but if you use common sense you will be fine and you can get plenty of advice on how on here or go buy a book for the car
****, you could drive a car with your feet
if you want to.
That don't make it a good ******* idea.
OP, you can buy a scalpel but it doesnt make you a surgeon. Spend the few bucks on a correctly built short block and eliminate the risk in a do-over. Understand where you're coming from but what's it going to cost you when (if) you have to do it again? Just sayin....
And how much is your time worth?
. I'm sure you can do it too The Best V8 Stories One Small Block at Time
A shop around here charges around $700 to assemble an engine after HE had it machined at the machine shop HE uses. Then you get a warranty if its used N/A......oh, and he tunes it for FREE.
maybe we should let these professionals assemble our stock shortblocks and then bang our women just so we don't screw that up too.
LOL
there is nothing wrong with building your own motor, i did and it's held up fine the past 2 years. there is also nothing wrong with using plastigauge, but you need to use it with the understanding that its not as accurate as mic-ing it out yourself.
if you don't know how to build an engine by yourself you need to find some kind of reference book to refer to,... but there's no reason to be afraid to do it.
Also, just an example of looking for the tools you need on eBay and craigslist, I just scored a $450 bore gauge off eBay for $135. It's a mitutoyo 2-6" with carbide anvils good to .0001". I also scored some brown and sharpe mics and a dial indicator for 40 bucks. About the only thing I lack now is a 3-4" mic for the pistons. All in all I have less than 300 in tools and they are all in good shape and name brand. Like I said, it doesn't have to be new. Just use common sence when buying stuff. If it doesn't look like it was taken care of, it probably wasn't.
Being that it's your first time why not have the guy put it together, or if you're close enough to his shop see if you can find the free time to go up there when he puts it together and LEARN.
I was fortunate enough to learn everything from my grandpa
exactly
