just beginning
Old Aug 13, 2011 | 12:13 PM
bugy's Avatar
Talking just beginning
hey guys, i just bought camaro 1998 5.7L LS iron block, it is all stock, i'm thinking to improve some parts, i dont have enough money now to do it, i'd like your advices, i was thinking to get cam kit first, then heads, maybe later a stroker, what do you think?
thanks
Old Aug 13, 2011 | 12:38 PM
RARON455's Avatar
Depends on what you are after,, all the power in the world will do you no good if you cant get it down the track,, DEPENDING ON BUDGET,, Start where everyone else does, Get yourself a set of longtube headers, a good y pipe, a good air induction kit,there are plenty of them out there, SEARCH this site for FREE MODS, there is a big write up on them. When you are done with that stuff get a mail order tune,,(Frost or TEXAS SPEED does more than any other) and you will feel a difference. WHen you want more than that, then its gonna start getting really expensive, The next step would definately be a cam, and intake, with a set of heads to go with. My old setup was a stock block with PRC stage 2.5 5.3 heads, a fast 92, with a custom EPS cam, the car made 463RWHP. Thats a stout street engine that will handle most comers, and hold its own at the track. IT all comes down to what you want to do with the car, and how much you can afford. I have a stroker engine,, IT WAS NOT CHEAP, and I built it.
Old Aug 13, 2011 | 01:14 PM
JohnS Z28's Avatar
well texas-speed sells heads/CAM kits.
But you should probably start with your bolt ons.
simple mods:
free Ram air, descreen MAF, P&P throttle body-$60, Lid-$100
moderate:
Headers-$500ish, Ypipe/Duals-$200-$300, ls6 Intake manifold$300-$400
advanced:
Heads+cam package from TSP-$1600-$1800
and lastly...a DYNO tune-$400-$500
Old Aug 13, 2011 | 01:39 PM
intenseblue's Avatar
Wasn't aware that there was a gen 3 5.7 iron block
Old Aug 13, 2011 | 05:08 PM
PREDATOR-Z's Avatar
If it is an iron 5.7 it most likely is a bored 5.3L...
Old Aug 13, 2011 | 08:52 PM
RARON455's Avatar
He's new, probably doesnt know its an aluminum block,,IF IT IS STOCK like he states.
Old Aug 14, 2011 | 12:36 PM
ZERO's Avatar
Is your car an auto or a six speed?
I would suggest a 3600 stall if your car is an auto. It was one of the best mods i did in the beginning.
Old Aug 14, 2011 | 01:52 PM
bugy's Avatar
well thanks guys all inputs are appreciated, it is an automatic transmission, also car is gonna be street/strip usage, so i suppost, i'm starting with simple mods, then i'll be going up
