Speed Inc Si7 cam with .030" milled LS6 heads, need to flycut?
I picked up a Speed Inc Si7 cam, I currently have OEM Z06 243's (sodium valved) milled .030, using the GM MLS .51 thick (compressed) head gaskets. How much (if any) should I flycut for these?
Thanks!
JD
Thanks!
JD
I've heard about a couple different methods, which do you recommend? One involves a light valve spring, the other I've heard was done with clay but I couldn't really understand exactly how the clay was to be used...
