Made A Crank Stop For Assembling Short Blocks
Old Aug 24, 2011 | 07:32 AM
Z33Art's Avatar
Default Made A Crank Stop For Assembling Short Blocks
I figured I would share this with everyone on the forum since I couldn't find any information on this. As those who have built motors know, the crank can be a pain to hold in place while torquing down things such as rod bolts and flywheels/flexplates. This is especially important if you use plastigage for checking bearing clearance.
Since I have been working alone on my engine and didn't have a second hand to help, I figured I would make a billet crank lock. What I cam up with something that bolted to the face of the block and had four incremented keyways allowing for easy clocking of the crank for rod installation and torquing. I have enough material left to make a couple more if anyone is interested in one. If I make more I will most likely add four more keyways at 45 degree increments.
I figured this was a better option than a flywheel lock since they are about $85 last I checked and sometimes it is near impossible to put the flywheel on while the block is on the engine stand. While this doesn't help with installing the crank pulley, it sure helps while assembling the short block and in my case installing the flexplate.
Let me know what you guys think. Motor is going to be a 383 with 12.5:1 compression.
Old Aug 24, 2011 | 08:39 AM
Callies Performance's Avatar
Nice Work! Nice crank as well
Old Aug 24, 2011 | 08:40 AM
PREDATOR-Z's Avatar
Good creativity! That is what hot roddin' is all about.
Old Aug 24, 2011 | 09:01 AM
Z33Art's Avatar
Lol. The crank and rods are awesome! Not that you are bias or anything
Old Aug 24, 2011 | 05:48 PM
joecar's Avatar
Good job excellent tool.
Old Aug 24, 2011 | 06:01 PM
Z33Art's Avatar
Thanks! I am about to go out into the garage and start working on the motor once more!
Old Aug 24, 2011 | 10:56 PM
Z33Art's Avatar
Here is a picture of the crank stop with the front two rods installed and torqued for checking bearing clearance. Rod clearance was just under .0025". Now it is onto cleaning everything really well once again and starting the final assembly of the block! I am going to finish making some more stops this week with the extra material I had sitting around. I will most likely put them up for sale for $35 shipped in the lower 48.
Old Aug 24, 2011 | 11:51 PM
Brad Hutchcraft's Avatar
That is a FANTASTIC looking tool! I'm interested in one!
Old Aug 25, 2011 | 01:00 AM
raven154's Avatar
Already paid for one! Can't wait to my stuff back from the machine shop.
Old Aug 25, 2011 | 07:03 PM
Z33Art's Avatar
All ready to go out tomorrow! Here is the updated version I am shipping you!
Old Aug 25, 2011 | 07:49 PM
raven154's Avatar
Looks slick. How did you broach the keyways if you don't mind me asking? Just from the clean lines looks like you have access to some nice machinery.
Old Aug 25, 2011 | 09:54 PM
Damian's Avatar
LSX Mechanic
I'll take one. PM me payment info. Thanks
Old Aug 25, 2011 | 09:59 PM
XtraCajunSS's Avatar
I'll take one as well. It's much better than the makeshift piece I've been using that bolts to the crank flange... What a PITA to constantly bolt and unbolt it on an engine stand. Your idea is genius. If possible, please PM me with info.
Thanks,
Shane
Old Aug 25, 2011 | 11:49 PM
Z33Art's Avatar
Using a really small tool.... .035" diameter tool to be exact....
Old Aug 26, 2011 | 08:30 AM
Damian's Avatar
LSX Mechanic
Thanks,
Shane
That's similar to what I've been using and it F'ing BLOWS. That tool makes me hate my life. This one will be much better.
Old Aug 28, 2011 | 10:03 PM
Z33Art's Avatar
I still have a couple of these left from the left over material I had if anyone is interested.
Old Aug 28, 2011 | 10:32 PM
Super6 N GA's Avatar
Default crank stop
i'll take one..send me you payment info.........thanks Bob
Old Aug 29, 2011 | 07:37 AM
TermnEatr's Avatar
x2 Me aswell!
Old Aug 30, 2011 | 06:46 AM
Z33Art's Avatar
All the locks have been shipped! Only a couple left and they are gone!
Old Aug 30, 2011 | 07:35 PM
Sarg's Avatar
sent ya a pm.
