Why is my car so slow???
they were pulling away from me like it was nothing.but ive seen it too many times here on tech with people on the stock cam and gearing just like me with big stalls running dam good in the 12's with similar 60fts.am i missing something?
with those mods you should be in the 12s. my friends auto 02 with a 4000 stall and long tubes and custom exhaust and lid ran 12.9 best and a 13.2 average.
you need to start looking into this motor and make sure everything is tip top, do a compression test and see what you get, I would also get a dyno run just to see if you are even close to where you should be on hp i know you have to take a dyno with a grain of salt but atleast it will give you a idea and a baseline. i would have the agree the 4000 stall is a little big for a stock engine and 3.23 gears but you should still be up therein the low 13s atleast and definetly better than a 2.0 sixty if your hooking descent.
look at your 1/8 time comapred to your 1/4 also and try to determin if your losing all your time in the beginning or overall.
OP, you have something wrong with your car. It is down on power. I personally would start with the simple stuff first-plugs, wires, filters, then check fuel psi, compression and leakdown.
Something is wrong. The first thing I'd do is a compression and leak down test. This will confirm that the motor is tight. If all goes well there, I'd get someone who's competent at scanning/diagnostic and start checking your sensors. Make sure the MAF is clean and functioning properly, 02's are switching like they should (although they zero out at WOT), check for misfires, etc. Also make sure your trans is shifting at the correct RPM. A stock A4 LS1 should be shifting around 5900-6100.
You don't need "this and that" parts. You need to diagnose a problem that's happening. Not band aid it with more parts.
