Why is my car so slow???
Something is wrong. The first thing I'd do is a compression and leak down test. This will confirm that the motor is tight. If all goes well there, I'd get someone who's competent at scanning/diagnostic and start checking your sensors. Make sure the MAF is clean and functioning properly, 02's are switching like they should (although they zero out at WOT), check for misfires, etc. Also make sure your trans is shifting at the correct RPM. A stock A4 LS1 should be shifting around 5900-6100.
You don't need "this and that" parts. You need to diagnose a problem that's happening. Not band aid it with more parts.
it does have a slight miss i think despite the new plugs and wires but it may just be motor mounts getting weak..cant really call it just yet.....
The easiest check is pull the MAF. If it has oil on it (a bad PCV can cause this), then it will murder your power. Fuel filters are stupid easy to change too. Hell, plugs and wires can be done in 90 minutes without breaking a sweat. If that doesn't seem to solve the prob, then follow Damians advice and get her looked at more thoroughally (complression tested/scanned).
Sorry, but it is not necessarily desirable get a converter that stalls to your peak torque rpm...A 4k is not optimal for a stock cam.
OP, you have something wrong with your car. It is down on power. I personally would start with the simple stuff first-plugs, wires, filters, then check fuel psi, compression and leakdown.
went and bought some maf cleaning spray and got her shined up,unhooked the battery...hopefully when i get back later and try her out, all will be well.......fingers crossed
now even if this isnt my issue right now...its still good maintenance...but im hopin this is it.
the pedal (or use a cinder block) while you go and look at the throttle
blade position. It had better be dead center in the opening. But I've
seen cars which, stock, only opened 75%.
When I first bought my car (10 years old) I consumed about a quart every 1500 miles. I had to blend in 3 gallons of race gas with every tank or I would get crazy detonation. Different intake, injectors, TB, and more importantly PCV delete and valve cover reliefs fixed it.
My understanding of the stall rpm is it should be set for approx 80-85% of torque gain on the incline and your shift points be at the at the same torque value on the decline, so you always cross the peak between shifts.
On the serious side, u should really check and make sure everything is up to par... Grab a good scanner and Check data and make sure the MAF is running like it should.
