Will this hit 400
Old Mar 4, 2004 | 09:15 PM
badaSS346's Avatar
Default Will this hit 400
Ok...i have done the research on the parts i think i should get and now i need your guys info. Will the following setup make 400+rwhp
224/224 .581 .581 cam (dyno tuned by one of them----------------------->)
Grottyhann style headers
SLP lid
LS6 intake
stock heads
pulley (if needed and there is only 1 right?)
ported tb (if needed and which one?)
no cutout...going thru slp d/d (gettin tb and pulley instead of magnaflow)
Its going through a 6 speed with 4.10's with stealth lower control arms.
Now if there are things i need please let me know.
Also..how important is putting a double roller timing chain and a z06 oil pump?
the car is a 2000 with 9000 miles.
Old Mar 4, 2004 | 09:24 PM
98SS Blackattack's Avatar
The avg for those mods is around 390.Could you hit 400-sure.I would make your goal speed not dyno numbers anyway.
Old Mar 4, 2004 | 09:31 PM
SnakeKiller's Avatar
You might be able to hit 400, but I think that'll be stretching it for a cam only car with that size of cam.
Old Mar 4, 2004 | 09:32 PM
99 Black Bird T/A's Avatar
~390ish...see sig as my set up is similar plus ported heads.
Old Mar 5, 2004 | 07:10 AM
kumar75150's Avatar
I would guess 385 with the 4.10s./
Old Mar 5, 2004 | 05:32 PM
badaSS346's Avatar
Is the zo6 oil pump that much better?
Old Mar 6, 2004 | 12:56 PM
JoSeY's Avatar
the Z06 oil pump is better, but I PERSONALLY never had a problem w/my 99...and I've got over 110,000 miles on the motor with MTI Stg 2 heads and X1 cam and some juice....
Old Mar 6, 2004 | 01:55 PM
Slowhawk's Avatar
LS1Tech Sponsor
I get an average of 380rwhp with what you have listed.
Old Mar 6, 2004 | 02:18 PM
Ryan02SS's Avatar
I'd say 380's also. I'm running the SLP DD muffler also and when I open my cutout I can tell a definate SOTP difference in power. The motor also revs noticeably quicker. Add a $30 cutout to your I pipe and hit 400rwhp.
