About to buy a trans am
Im running a Felpro rear main with no problems. As for the headers, they are prone to crack where the emissions fittings are welded to the primaries. I prefer a non-emissions header and then you can do a mail order tune to delete your emissions in the computer. You could get them to throw your trans tune in while they are at it. Check out Frost for mail order tunes. Good luck Headers & Y-Pipe (Stock exhaust is leaking)
Frost Mail Order Tune (Delete cats & rear 02s so you pass emissions)
Rear Mail Seal (Stock gasket is leaking)
3000-3200 Stall Converter (Performance part that can be done w/ rear mail seal install)
New Plugs/Wires (Most likely the car currently has alot of miles on them)
And then from there you can upgrade other parts such as an LS6 Intake, ported throttle body, underdrive pulley, etc etc.
As for cats with long tubes, I'd say get the TSP catted-Y if you can afford it.
Circle D makes an affordable 3k stall TC from a modified OEM trailblazer TC that many seem to like.
