Cam advise please!!!
Old Aug 30, 2011 | 09:04 AM
Ronny_02_WS6's Avatar
Default Cam advise please!!!
I know you guys are probably tired of seeing threads like this but In my case is different, speciallly in another country.
I'm a soldier currently stationed in Germany and I have a 2002 manual WS6, my only mods are K&N FIPK
I bought comp cams 7.400 pushrods and Patriots dual springs with locks and seats, planning to get a pulley, lifters and timing chain. I want to buy a cam that is mean in the street and give me all the hp/torque I can get with stock heads and manifolds with a flowmaster muffler, if I can get to the 400s it would be better, I dont want to buy heads or headers, I only drive my car like 2 miles a day to work, Im planning on mailing my pcm cause theres not tuning in here, Ive read about the EPS 224/230 111 lsa and the CheaTR cam, is there any other toughter cam out there for MY SET UP? I want to be able to sweep some BMWs and GTIs up here with just a CAM. PLEASE HELP ME! I would really appreciate it.
Old Aug 30, 2011 | 09:54 AM
davidws6's Avatar
With a M6, and a 224/230 on a 111 LSA, gonna be a lil touchy off idle. Also I'd think with a lot of bucking on a 111LSA, if it has the stock 3.42 gear ?
No headers + a Flowmaster, it's not gonna breathe good enough for the cam to have much of an advantage. With headers and a Magnaflow or something that breathes better, you might see 400 !
After you install a cam you should still check the pushrod length to verify the 7.4 will be ok!
If your going to do a mail order, Try Frost on here as I hear his mail tunes are very good.
I helped a friend tune his Vette on the Autostrada in Italy ( A 1 ) That was a blast zooming past the slower Ferrari's !
Old Aug 30, 2011 | 11:16 AM
Cool, Do you have any cam suggestion, I also read about TSP 228R.
Old Aug 30, 2011 | 11:49 AM
Detoxx03's Avatar
Something in the 228-236 range. Not having headers is gonna hurt you but having no headers plus a flowmaster muffler makes it worse.
Old Aug 30, 2011 | 12:22 PM
hiltsy855's Avatar
Do some searching on Thunder Racing 230/224 or 227/224. With stock manifolds & heads the reverse split cam is supposed to work very well. The 230/224 has an awesome idle sound, the 227/224 is toned down quite a bit. Frost will have a good mail-order tune for that setup.
Old Aug 30, 2011 | 01:52 PM
Would shorty's help???
Old Aug 30, 2011 | 01:53 PM
I didn't thought about that, sounds good.
Old Aug 30, 2011 | 02:13 PM
Detoxx03's Avatar
Waste of money in my opinion
Old Aug 30, 2011 | 04:06 PM
I Think I'll just wait for a complete set up with LT's, Y pipe and a complete exhaust. Maybe at Tax return
Old Aug 31, 2011 | 10:34 PM
hiltsy855's Avatar
I wanted to correct my statement above. This thread indicates a reverse split works well with long tube headers and stock heads & intake. Sorry for the confusion.
Old Sep 1, 2011 | 01:10 AM
I'm planning to get headers and Y pipe no more than $500 I heard good things about the bbk PN 16940 it's $499.99 Anybody have any comments or suggestions about LT's & Y pipe for that price range??? And maybe a hooker catback or tsp rumbler or flowmaster american thunder???
Old Sep 1, 2011 | 01:20 AM
lemons12's Avatar
if you are tight on money but have to mod.... Budget.
Exhaust
Pacesetter painted headers with pacesetter (or TSP) ypipe
cutout- you can buy them cheap on summit for like 35-40$
I would recommend something around 230/234 .600 111 for the cam..
You will also need a new clutch, you will fry your stocker quick with the added power.
You need exhaust with a cam!
Old Sep 1, 2011 | 02:51 AM
Exhaust
What brand and stage for the clutch with those mods??? Would the Ram HDX from TSP $320 work, it says up to 450 hp?
Old Sep 1, 2011 | 03:24 AM
z99ls1's Avatar
Restricted User
Exhaust
This^^ is exactly what I was going to recomend. Try to get as many bolt-ons as you can before you do a cam. It will make the cam seem so much better when you get it in.
Old Sep 1, 2011 | 03:19 PM
lemons12's Avatar
I know nothing about 6 speeds as far as which clutch to go with. I would call Texas Speed and ask what they say.
Old Sep 2, 2011 | 10:54 AM
Ok, thanks for the advices, I will put all the bolt ons that I can first, then get me a cam no bigger than a torquer V2.
Old Sep 8, 2011 | 10:07 AM
Exhaust
So what you think about this one ''ANYBODY''
Crane Cams 228/232 .600/.600 112 LSA???
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,700-6,200 Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 232
Duration at 050 inch Lift 228 int./232 exh.
Advertised Intake Duration 290
Advertised Exhaust Duration 294 Advertised Duration 290 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.600 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.600 in.
Valve Lift with Factory Rocker Arm Ratio 0.600 int./0.600 exh.
Lobe Separation (degrees) 112
Old Sep 8, 2011 | 02:28 PM
lemons12's Avatar
That cam would do just fine.
Old Sep 9, 2011 | 07:23 AM
Sorry to ask more questions but, If I have my stock 241 heads ported, would that be even better for that cam???? , I just wanna be on the safe side.
Old Sep 9, 2011 | 10:12 PM
lemons12's Avatar
They would definitely help, heads will make it a different car! However if I were you I would spend an extra 400$ and grab a set of ls6 heads and get them ported.
