Help! Crank only turns 180°
i try to not buy ANYTHING expensive sight unseen.
was/am looking for a flatbed. i've got limited funds to spend on one.....thought i found a decent old chevy for less than 5k. the guy's local, was gonna bring it by my shop. then when he didn't show, it was because the clutch went bad. then he's offering it to me for 3500 as is. the story changed too many times during our conversations. from runs great to bad clutch to it makes noise at 50mph.
i'm making a phone call today on a ford with a 460 19ft alum. bed, and a 5 speed.
On the plus side, I've learned a ton about this car. Kind of feel like I have a connection with it, if that doesn't sound too strange. And made great friends with my mechanic (just imagine, give somebody a good couple thousand dollars and you'll have a friend!). He's donating a bunch of parts and we do a lot of the work together over a couple of beers.
we like working on them, when we get the chance. every guy whos hot rod i've worked on has been cool people. from the guy with the 69 302 powered z28.....which i friggin LOVED that car......to the guy with the 89 gta that i'm working on right now......these are cool guys.
the guy that used to own the z28 moved to mass., but comes back to visit nj once a year. he always makes it a point to stop in the shop to bs for awhile.
here's another possible bright side on your car........if you don't get this engine going, you've got what sounds like an otherwise decent car, just BEGGING for a crate motor.
also, i wouldn't feel bad on the being impatient part......we've ALL done it at least once.
what DOES **** me off, is if the guy knowingly sold you the car with basically an effed up engine.....it pisses me off to no end to see someone take advantage of those that protect our country.
Whats really scary is considering the extremely basic operation of the crank spinning was overlooked, how much detail was paid to the dozens of other clearances and small details that can make or break (pun intended) an engine??
Scary stuff......OP, good luck working it all out!
-Tony
But, she fired the other day. I'm putting the exhaust on next time i go over there, and then we'll hook up the fuel lines and see what happens
