which cam for what i want?
Old Sep 8, 2011 | 04:55 AM
2000SSMAN's Avatar
Default which cam for what i want?
Hi. Im trying to find a cam to eventually put in an ls1. I want a cam that is good on the street but still has 110-112 lsa, .550-.600 lift, prob 230's duration, and i would like for the powerband to start at least by 2000 and go to about 6200. Idk if im asking for too much to go into one cam or not. Ive looked into multiple cams and im kinda leaning toward the torquer v2 but i think i read somewhere that the powerband doesnt start till like 3000. So, if anyone has any suggestions it would be greatly appreciated. Thank you.
Old Sep 8, 2011 | 05:31 AM
ausls1's Avatar
http://www.compcams.com/Company/CC/c...csid=1403&sb=0
this comp cam maybe, revs a bit higher but starts at 2000rpm and is a 113 on a 109 center.
Old Sep 8, 2011 | 06:02 AM
2000SSMAN's Avatar
thats pretty close but i would like something with a wider lsa if anyone can find something (110-112), i love a choppy idle but want it still to be streetable. I appreciate the research on the comp cam.
Old Sep 8, 2011 | 06:05 AM
speedtigger's Avatar
Old School Heavy
In an LS motor, this would require a small camshaft. For that power range a cam in the 220 @ .050" on the intake would fit the bill.
Old Sep 8, 2011 | 06:10 AM
2000SSMAN's Avatar
yeah ive saw some of them but im trying to find something a little bigger....do you have any suggestions for a bigger cam with wider lsa and kinda early powerband
Old Sep 8, 2011 | 07:29 AM
Old School Heavy
The wider the LSA the lazier the cam will be down low. For example, a 110 LSA cam will exhibit better torque than a 114 LSA cam. So, if you try to go bigger and want a cam that maintains better torque, you night a narrower LSA.
Why do you want a bigger cam? For the idle?
Old Sep 8, 2011 | 09:30 AM
2000SSMAN's Avatar
A 110 would be more choppy than a 114 right? I had a 106 in a carbed 355 and had to switch to a 110 cuz it ate a lobe but the 106 definitely seemed to be more choppy......and i want a cam for power early and often but i want it to lope....i am also going to be building a motor when i have more money and im just trying to find a cam that ill be satisfied with cuz most of them are pretty expensive so i only want to do it once. The 228r is okay but i dont think its quite as aggresive as i would want. If at all possible i wouldnt mind having a list of a few big cams and a little smaller cams to go with.
Old Sep 8, 2011 | 09:49 AM
Detoxx03's Avatar
228/230 from Futral Motorsports
Old Sep 8, 2011 | 10:06 AM
2000SSMAN's Avatar
whats the lsa on the futral? what about a cam like the vrx4, vrx5, or the g5x3? just trying to find out as much as i can. thanks for all the help so far
Old Sep 8, 2011 | 10:20 AM
Rise of the Phoenix's Avatar
Either 112 or 114, you pick. You could always have him grind you that cam on a 110 LSA. I think that would be your best bet. Not too big, but big enough for your goals, plus will sound down right nasty at idle.
Old Sep 8, 2011 | 10:24 AM
2000SSMAN's Avatar
how much does a custom grind normally cost?
Old Sep 8, 2011 | 12:06 PM
V68Sweep's Avatar
OP,
Call Comp Cams and tell them exactly what you are looking for. They can do custom grinds for a very small additional cost. They will be able to direct you to the best possible option, especially if you are willing to have them build you a custom cam.
Old Sep 8, 2011 | 12:08 PM
V68Sweep's Avatar
Whoops, looks like I came in just a minute too late. But yes, call Comp http://www.compcams.com/Company/CC/C...amHelpNew.aspx 1-800-999-0853
Old Sep 8, 2011 | 12:37 PM
It all depends on who you go with. In my opinion, I'd go with Alan Futral of Futral Motorsports. Go on his website, all the info you need is on there. He's the designer/maker of that cam Detoxx suggested; 228/230. You could always just tell him you want that same cam, but on a 110 LSA. I don't think it will cost you anymore than what he charges for his off shelf cams.
Old Sep 8, 2011 | 01:08 PM
2000SSMAN's Avatar
do you think it would have enough vacuum/street manners with a 110?
Old Sep 8, 2011 | 01:31 PM
_max_POWER's Avatar
The F11(futral 228/230) is the same cam i have for my build but on a 114+4.
. Hope it does the job!
Old Sep 8, 2011 | 01:55 PM
2000SSMAN's Avatar
does anyone have an opinion on the VRx4 or VRx5 or g5x3? any problems or good experiences......do you have to flycut?
Old Sep 8, 2011 | 04:28 PM
Killer5.3's Avatar
The lower the number on LSA the narrower not wider. Wider would be 117 for example. If you want power below 3000 then you definitely don't want to go any lower than 114 probably. You will have to decide if you prefer chop in the idle as you said or power down low. Can't have alot of both. Look at some of the sound videos on youtube of alot of the various popular cams for ls1 and that should help you decide on what sound you like if that is your priority or you can find a happy medium. The 224 @.050 duration cams sound pretty good on a 112 LSA and make pretty good power down low.
Old Sep 8, 2011 | 04:34 PM
Killer5.3's Avatar
Clearance will depend on several factors including whether or not you change heads too. Chamber volume could effect clearance. The VRX4 and G5X3 should both clear with stock heads ,but, you should measure clearance to be sure. Both are very good cams , but, really need at least 3.73 gears but 4.10-4.11 would be better in a stick car. The VRX4 is milder duration than the g5x3. VRX4 would be the better of those two for what you are wanting but I would definitely not rule out some of the smaller ones like the thunder racing 224 on a 112 LSA.
Old Sep 8, 2011 | 04:56 PM
01ssreda4's Avatar
Have Pat G spec your cam....
