which cam for what i want?
Im thinking im leaning toward the vrx4 i have researched many cams on youtube and other places. I think its the closest to the total package for what i want. Do you think it would work with a set of trick flows? and thanks for all the suggestions everyone
this thread might help u pick a cam it's close to your origanel plan and made good power.
https://ls1tech.com/forums/generatio...am-change.html
1998 WS6 | Moser 9-inch | 4.56 gears
Long Tube Hdrs | Off-Road Y-Pipes | Loudmouth 1 cats
Trick Flow Cam | .228/.232 | .595/.595 | 112 lsa
Hear it here....
http://www.youtube.com/playlist?list...tknOdlgeo8-ozY
Hear it here....
Hear it here....
Hear it here....
Try this
http://www.youtube.com/watch?v=TPSC-...B13193&index=1
I have no idea why Utube will not run for you, let me know if this works
MASS seller approved
try this
http://www.youtube.com/watch?v=tpsc-...b13193&index=1
i have no idea why utube will not run for you, let me know if this works
i have the vrx5 in my camaro and it works awesome, it has the nice choppy idle plus the power. it seems to start creating power around 2500 rpm tho but all in all i like the cam
#32
vrx4 is a 228-230 with 588-592 lift so power everywhere. do a search on it "228-230 dyno". some nice numbers on it. so many cams out there can make it hard for me to decide so i try to go with what proven and will meet my needs and wants. good luck with your project.
#34
Try this
#35
More sound...
Cam: .238/.242, .595/.595, 12 LSA
Cam Range: 1,050 rpm to 6,800 rpm. Rev limiter 6,500
Cam Power range: Peaks at 5,000.
Gears: Moser 9-inch, 4.56 gears, Detroit Locker, 31-spline axles,
Headers: Hooker Long Tubes. Off-Road Y-Pipes. No EGR. Loudmouth 1 exhaust
Tires & Wheels: Stock WS6. Rear tires are photoshop (not real).
Over-sized widths can be made to work with off-sets and customizing (hammer) fender wells.
In conjunction with the 4.56s, the rev limit in 1st gear is quicker than a heart beat. It revs so fast, the tachometer can't keep up. It lags so far behind the actual rpm that it's useless in 1st and 2nd gear.
http://www.youtube.com/watch?v=Bk0QS...F-qI2_hoRA_k1A
#36
#37
Over-sized widths can be made to fit using off-sets and customizing (hammer) fender wells, but these aren't real.
In conjunction with the 4.56s, the rev limit in 1st gear arrives quicker than a heart beat. It revs so fast, the tachometer can't keep up. It lags so far behind the actual rpm the tach is almost useless in 1st and 2nd gear. With this setup, a shifting light is a necessity.
Now you can see how much a set of tires can improve the beauty of your LS1. If you're not impressed with the looks, you can spend your money on mods that are more important to you. I'm springing for a clutch setup for my next outlay and i'm for going the tires.
Now that you've seen how the fat tires will look on your ride, who is going to be the first of us to go for that look?
#39
Just do a custom cam like this: 227(.614")/227(.614") 110 lsa +3 with CompCams LSL lobes(7* overlap). At .200" lift it's like a 230/230 XER lobe cam, so you can still benefit from using these lobes over the XER lobes even if your heads can't flow great above .600" valve lift. For a power band a little closer to what you want go with a 223/227 110lsa +3 w/LSL lobes (w/5* 0verlap), which will still have a very nice cam sound.
http://www.texas-speed.com/p-161-com...-camshaft.aspx
It'll sound very similar to mine(227/231 111 lsa+2 w/lsl lobes w/7* overlap).![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
http://s523.photobucket.com/albums/w...nt=CAM2001.mp4
