LS1/BMW Lower end knock
New rings - 166.47
Cam bearings - 36.48
Gaskets *2-es-72173* - 53.22
Gaskets *260-1910 - 347.20
Crank kit (Used crank) 299.20
Rods (2) - 100.16
Oil pump - M-295 - 98.71
misc - 45.00
pin fit/clean/align - 60.00
Hone cyl - 64.00
Install cam bearings - 50.00
Hot tank/degrease - 160.00
Assembly - 100.00
shop materials - 25.00
Basically, 2 rods, a crank, oil pump, re-ring again, gaskets, bearings, clean, and assemble for 1650.
http://www.youtube.com/watch?v=NnpQjA-ViBs
its really inconsistent then becomes really fast and i shut the motor off..so i haven't ran it long..but nothing taps when i remove the ign relay and fuel relay..only when the car is actually running it taps.
2002 LM7
275$
90 day warranty
142k
Drove up to kalamazoo michigan and picked it up in my DD. I left at 530 and ot back home/work at 11:02. The employees there were like, OMG, that wont fit in there, you realize its a truck engine right. So after arguing with everyone for 15 mins, i told them to put it in the hatch and if something happened, its on me, but youre going to make me late for work. The guy got out his forklift and sat it in the hatch, 2 mins later, i had it bolted and chained to the bmw and was on the road.
Once at work, pulled it out and put it on the engine stand.
Tore it down, over the next couple of days, cleaned and painted, and now im at reassembly.
I should but up and running before the end of the weekend.
Pont 400 in a old dodge ram, chevy sb in a 79 scout and a few others.
The bmw interface was pretty simple actually. The hatchback is the lightest e36 available from the factory, weighed in at 2900 with the ls1 installed which is only 55 more lbs than the stock 1.9L with a 5 speed and smaller differential. I had to build a small relay and fuse box for the swap which consists of 12 fuses and 6 relays, none of which is difficult at all. Add the bmw connector to the end of the harness and everything is PNP. I ran the bmw coolant temp sensor to the passenger head for reading in the cluster, the tach is automatically calculated, speedo is in the diff, gas is chassis based, oil pressure and voltage guages were added to the dash.
