243 and 799 heads
Old Sep 18, 2011 | 07:27 PM
camross998's Avatar
Default 243 and 799 heads
ok just finished my cam and head swap finally. well i swap cam first and got the car tuned it a 99 a4 t/a with a (lq4 and 212/222 550/549 116+3 mac mid headers lid) i had 853 when i got it tune then i swap for 243/799 head.what I want to know is will the 243 throw my tune off enough for me to lose power. or should i get it tuned again to feel the gain
Old Sep 18, 2011 | 07:48 PM
snakeskinner1984's Avatar
Are they just stock 243/799 heads?
Old Sep 18, 2011 | 07:52 PM
camross998's Avatar
yea just stock no port work
Old Sep 18, 2011 | 07:55 PM
ls1ya's Avatar
I would get another tune but thats just me. Maybe your tuner will cut you a deal. Seems like the extra airflow would need to be accounted for.
Old Sep 18, 2011 | 08:52 PM
Yea I would get another tune also because the 243/799 flow a good bit more than the 853 heads that's what I would do. You may see another 30hp out of the just heads.
Old Sep 18, 2011 | 08:54 PM
I would also mill the heads about .30 to get the compression ratio back up on the lq4 to like 10.5:1
Old Sep 18, 2011 | 08:56 PM
If the heads aren't on the car yet.
Old Sep 18, 2011 | 09:09 PM
camross998's Avatar
was the compression higher with the 853 or is it higher with the 243 or the same
Old Sep 18, 2011 | 09:34 PM
Someone correct me if I wrong but I think it would be about the same with the 243 heads. But didn't the lq4 come with 317 heads and the 853 come on some of the ls1 cars?
Old Sep 18, 2011 | 09:40 PM
Isn't the lq4 9.5:1 with the 317 and if you put the 853 or 243 heads with out milling them it would lower the CR because of the combustion chambers but I may be wrong some correct me if I wrong.
Old Sep 18, 2011 | 10:03 PM
01ssreda4's Avatar
LS1 heads have bigger chambers then 243/799 heads meaning you get a bump in compression going to the better head. It roughly breaks down like this (based on memory): Higher the number, lower the compression
317 head: 72cc
LS1 head (853, 241): 67cc
LS6 head (243, 799): 64cc
5.3 head: 62cc
Old Sep 18, 2011 | 10:36 PM
camross998's Avatar
so question is whats is my compression now with the 243 head and stock head gasket
