PAC 1518 Spring Questions
Box says:
Batch # 38367 / 4-1-11
Installed: 130 lbs @ 1.800"
Open: 318 lb @ 1.200"
Rate: 313 lbs/in
If you do the math based on the numbers above, the force between the two spring length points of 1.800" and 1.200" correlate with the 313 lbs/in spring rate.
I measured the un-installed free length of the springs with a digital caliper and came up with an average of 2.315".
If the spring is compressed from 2.315" to 1.800", that is a compressed distance of 0.515". That equates to a force of 161 lbs @ 1.800" (using 313 lbs/in), which doesn't match the PAC spec of 130 lbs @ 1.800" on the box.
Likewise, if compressed from 2.315" to 1.200", that equates to 349 lbs @ 1.200" (using 313 lbs/in) instead of the PAC spec of 318 lbs @ 1.200" on the box.
Is the spring rate really not linear in the first part of compression? I don't have a spring tester.
Is the free length of these PAC 1518 springs too long? Why don't the force numbers vs. compressed distance correlate closer? Maybe I'm missing something on how PAC comes up with their force vs. compressed length specs (?).
I recall seeing a PAC Tech here on the board (don't recall your user name) ... could you please also chime in - thanks!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
But if the spring rate of 313 lbs/in was truly linear and constant from zero compression (ie, free height) to the 1.800" installed height, then theoretically the force at 1.800" should be equal to free height minus 1.800" times spring rate.
Maybe the spring rate isn't really that linear?
I'd like to know what the nominal free height of the PAC 1518 springs are supposed to be just to feel good that this set isn't out of spec for some reason.
Anyone have a new set of PAC 1518s sitting around where you could measure the free height of a couple and post the results?
Even is they were made a little too long in free height, it only adds ~30 lbs to the specified forces. Probably isn't going to hurt the valves or seats, although the stock yellow springs are supposedly only 90 lbs at installed height of 1.800". These PAC 1518s could potentially be around 161 lbs at 1.800".
Just want to make sure I don't use something that's not right.
Again ... if anyone has some new PAC 1518 springs laying around, I would appreciate it if you could measure the free height of a few and let me know what you measure.
IMO, just set them to the proper seat/installed height and don't worry about it.
Anyway ... about the installed height. I'm just replacing the springs and using all the OEM retainers, locks and seats (seats are the metal base of the valve guide seals). So I take it the installed height on these springs will be exactly what the OEM springs were at, which I believe is also 1.800".
The spring's installed height is defined by the distance between the seat surface and the retainer surface when the valve is closed, which hasn't changed in this case. So I shouldn't have to worry about the installed height needing any adjustments ... right?
What ever the installed height is from the factory based on the distance from the valve guide seal "seat" to the bottom surface of the spring retainer is what I'm stuck with. The distance from the spring seat to the bottom surface of the spring retainer (ie, installed height) is defined by the assembled configuration of the retainer and locks on the valve stem when the valve is closed. None of that can be changed with OEM parts.
Other calculations (not shown) indicates that the spring stiffness slowly changes from 260 lbs/in at the installed height of 1.800" to a rate of 360 lbs/in at a compressed height of 1.200". The 'average' spring rate between 1.800" and 1.200" is the advertised 313 lbs/in you see on the box.
Good to know.
