MTI Motors Question
Old Mar 8, 2004 | 12:08 PM
sununix69's Avatar
Default MTI Motors Question
If you had a choice of the 387 all bore pacakage for 6K or the 383 Stroker package they have for $6K also which one would you go with?
What are the pros and cons?
Old Mar 8, 2004 | 12:26 PM
deviate42's Avatar
try a search. stroker vs bore has had many threads
id take the all bore
Nytmare's Avatar
I would go with the all bore motor because the motor will insure that i'm expoiting every possible inch of cfm out of my heads ! Regardless of valves ! Just my opinion, but if i have a BAD AZZ head that flows 340 with 2.08 or so valves ITS GOING ON AN ALL BORE MOTOR ! I might not no what i'm talking about, However, that stroker will not take advantage for your high flowing heads with the big valves in it .. Pound for Pound, Stroker down the 1/4 or All Bore down the 1/4 .............ALL BORE in a HEARTBEAT !
Old Mar 8, 2004 | 12:29 PM
sununix69's Avatar
Yes sir I have tried but not sucessfull. I mainly do not know the difference between a bored vs stroked motor, and which has more hp/tq under the curve and what kinda track times etc.
Raj
Old Mar 8, 2004 | 12:31 PM
deviate42's Avatar
Raj
sry. my post prob wasnt very helpful
for the most part, strokers make more torque vs a bore which will make more peak hp. an all bore can see higher RPM's over a stroker motor as well.
Im sure you could see high 10's to low 11's with a mild setup on either. it depends about you car setup.
Old Mar 8, 2004 | 12:52 PM
sununix69's Avatar
Excellent info thank you! I see that the dyno sheet on their website shows that the 387 makes more peak HP, but the 383 stroker has a flatter torque curve. Just curious in your opinion for a mainly street, once in a while track (I have a 9 inch rear though hehe) car 387 all bore should not be too bad right?
Old Mar 8, 2004 | 01:16 PM
kumar75150's Avatar
all bore will probably make more power
Make sure you get the details on the warranty though. There have been several polls on this forum showing how many people have had problems with big bore motors.
Old Mar 8, 2004 | 07:09 PM
maddboost's Avatar
If your looking for mostly street use I would recommend the stroker because of the flatter and more useable torque curve.
Old Mar 8, 2004 | 07:18 PM
Chicago Crew UnderBoss's Avatar
Why don't you to the best of both worlds & both BORE & STROKE that BIAATCCHH!!!
Old Mar 8, 2004 | 07:31 PM
maddboost's Avatar
Jim not all of us have your unlimited resources.
Old Mar 8, 2004 | 07:37 PM
YOU really mean UNLIMITED CREDIT CARD DEBT (that's 1000% more accurate)!!!!!
Old Mar 11, 2004 | 10:13 PM
sununix69's Avatar
I want something like a Vipers low end torque. I know whenever i ride in my friend(s) vipers it feels like that thing can just pull and pull and pull. Yes I realize they have 2 more cylinders lol But which would give me a LOT more low end torque and also give me the capacity to runn low 11's maybe high 10's on motor, and still be dependable for a daily driver?
sununix69's Avatar
The reason is i have the money already and since MTI has the best deals, liek WHOA Stroker motor, block etc all and heads and cam for 6K I was like SOLD!!!
Old Mar 12, 2004 | 06:22 AM
SAM98WS6's Avatar
better check again...shortblock only is $6k...no heads..you have to go to ls1speed or keith kraft to see the cheapest prices on longblocks..~$7k. I dont know if you get what you pay for so I decided to build my own STROKER because I want the torque too and didnt want to worry about the block leaking.
Old Mar 12, 2004 | 09:05 AM
beardWS6's Avatar
Go stroker and put a big shot of spray on it. A stroker motor is tough as ****. Then throw a 150-200 shot of spray and push yourself into the 9 sec zone! My stock Block with MTI heads, X1 cam and 100 wet shot puts me in the 10`s with 555rwhp. I want a stroker bad and MTI builds the best. They did everything on mine! You Talk about a sweet ride. I love it! Check Sig!!!
Old Mar 12, 2004 | 09:54 AM
poolfanatic's Avatar
Badass pool player
I'd go with a moderate compression 383 stroker with ceramic coated Wiseco pistons and Lunati internals, then throw a nice (150) shot of gas on top of it.
That will give you the torque you're looking for and then some!
Old Mar 12, 2004 | 10:45 AM
NOTAV6's Avatar
Gotta respect the willingness to go deep into debt for a muscle car. Very nice
Old Mar 12, 2004 | 11:29 AM
JZ'sTA's Avatar
Try doing a AP or LS1spped cheep street short block for 2800 dollars. This would be a complete shortblock with all good parts. Then buy a SC and run 12psi. Talk about spending a little more money to get a whole lot more performance.
There is a 600+HP all the time setup right there. I am cheep and run Nitrous myself but if I had the money this would defentially be a option in a everyday driver.
Your friends Viper would feel like a Civic.
Just my .02
Anyone agree????
Old Mar 12, 2004 | 12:58 PM
Benjamin Russick's Avatar
I'm not really sold on forced induction for the LS1/6, so I'd have to dissagree. I did a lot of research before going with a head/cam package over FI. I think FI will eventually be awesome on the Gen III, but it isn't there yet...
Old Mar 12, 2004 | 12:59 PM
kumar75150's Avatar
From what I have seen, MOST not all supercharged cars have issues at the track and oftentimes on the street with belt slippage.
