Bye bye ls1
Old Sep 30, 2011 | 11:45 AM
98blkz28's Avatar
Default Bye bye ls1
So it's Friday a lil before 1pm and I think my ls1 just computes sucicide. I had a tick from loggers rockers somewhere, was gonna start soon but need the car for work. So now I'm sitting a burger king :/ so ls1 tech what's my move? Lq4? Ls1? I was thinking lq4 and Rebuildig the ls1 for a s14 240
Old Sep 30, 2011 | 01:15 PM
3rdCoastPowerSports's Avatar
didnt you just have a video up with your ticking noise? if so didnt you say you had needle bearings in your oil
Old Sep 30, 2011 | 01:37 PM
adamantium's Avatar
lq9 should be your next move.
Old Sep 30, 2011 | 08:20 PM
98blkz28's Avatar
Yea i did, I was about to open up the motor...but today it just stalled out and made a nail on chalk board sound when I tried to restart it. I was trying to get to work and babying the motor
Old Sep 30, 2011 | 08:39 PM
98blkz28's Avatar
LMAO @ the Iphone text correction..i have no clue
Old Oct 2, 2011 | 11:21 PM
98blkz28's Avatar
***UPDATE***
So I just got done with replacing the rocker arms and this is what is going on:
New rockers
good oil pressure
bad part there is a loud knock from the valves or pistons.
I'm uploading videos
Old Oct 2, 2011 | 11:32 PM
SladeX's Avatar
Mine when giant rock in a can sound before I threw 2 rods... Go LS3....
Old Oct 2, 2011 | 11:34 PM
98blkz28's Avatar
http://www.youtube.com/watch?v=NnpQjA-ViBs
Old Oct 4, 2011 | 04:10 PM
Tony Nichols's Avatar
That nail on chalk sound...ive had that sound with mine. #5/6 rod bearings.
Old Oct 5, 2011 | 02:09 AM
98blkz28's Avatar
it did it once..now its not doing it just that loud knocking sound..i'm guessing valves..im opening the covers tmrw to see if my rockers are too big..SIGH!! I thought and was hoping it was just those!
Old Oct 5, 2011 | 03:11 AM
z99ls1's Avatar
Restricted User
Old Oct 11, 2011 | 07:20 PM
98blkz28's Avatar
Ok, so i have done my rockers as per the book, unplugged all cylinders individually and multiplie ones (left and Right) there is still a knock.. Im thinking camshaft or crank heres the knock on audio only with it cleaned up.
http://www.youtube.com/watch?v=hbY7clSDzN8
Old Oct 11, 2011 | 07:44 PM
DarkFox118's Avatar
ok I'm no expert.. but that sounds like rod bearings to me.
I'd say that thing is hosed man.
I went with a salvage yard Lq4. It was cheap, but i'm not so sure i'm gonna stick with it just yet. LQ9 would be better if you're gonna stay NA. Bit harder to find but still a great choice. 400-450WHP easy.
Old Oct 11, 2011 | 07:46 PM
SOMbitch's Avatar
That is a spun bearing dude.....sorry......
Old Oct 11, 2011 | 07:55 PM
Blasko's Avatar
Total Noob mode here. But how would a spun bearing ave it make that knocking noise?
Old Oct 11, 2011 | 07:58 PM
DarkFox118's Avatar
it makes that noise because of slop as it is my understanding. the piston rod is banging around as the crank moves. Eventually the bearing will come loose, bind against the top bearing and lock the engine down. Could damage the block. best if you stop now, take it apart, maybe the block is still good.
what worries me is his earliest ticking noises are similar to the sound my car has been making for about 6 months now. think mines just noisy valvetrain though.
Old Oct 11, 2011 | 08:01 PM
98blkz28's Avatar
Mine started as possibly rockers. Well I dont know if it want to do a total motor swap..my best bet would be to just leave it off.. open it and see what it is..bc i just want to get it running so i have transportation. If it is a spun bearing can't I just replace the parts?
Old Oct 11, 2011 | 08:03 PM
98blkz28's Avatar
and if im going to have to open up so much of the motor i might as well rebuild it and clean it and make it better then stock
Old Oct 11, 2011 | 08:09 PM
LS1MCSS's Avatar
If it's a spun bearing, the motor has to come out. just replace it before you damage the LS1 block. You can always sell it to recoup part of your money.
Old Oct 11, 2011 | 08:14 PM
98blkz28's Avatar
So if its not beyond repair. I can clean it up and fix the issue or possibly do a swap.. I kinda wanna swap it, save the motor fix it and put it in a s14 240
