How many hours labor for cam swap on 5.3 truck?
I have the cam I think I want but I'm not doing the install if I don't have to($$$). Must the intake be removed ? I have heard you can hold the lifters up with magnets and pull it out front. I don't want the truck down long so I will hire the job out.Does any one know the book hours on the swap? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Thanks,Jim
Re: How many hours labor for cam swap on 5.3 truck?
Jim,
Seems like the book time is 3-5 hrs from what I recall. It is really not too bad a swap. The intake does not have to come off, and you really don't even have to have the magnets for the lifters. You can just spin the cam a few times while still in the block, then pull it out. The lifters will hold themselves up for a few minutes. Magnets would be good for piece of mind though! What cam did you decide to go with?
Ryan
Ryan
If you have to do springs, I'd say 4-5 hours. The intake stays on and you won't have to pull off the A/C system. Radiator stays in. you will just have to have someone hold it up out of the way while the cam is removed and installed.
LSxGuy widda 9sec Mustang
Book time don't matter, any shop can charge what they want to install anything. FYI the book time for a camshaft would include the labor for removing the cylinder heads since that is the proper procedure per the service manual (something like 12+ hours from what I remember). <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I would say shop around, your looking at anywhere from $400 - $600 for the install labor with valvesprings at a knowledgable LS1 shop using the common shortcuts. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
billy at speedtek in hurst tole me 350 to do cam and springs a few weeks back when i was feeling like i didn't want to do it, but i got back into the feeling and now i want to do it again so i'm getting it done free.
