HP Stock LS1 Crank Can Handle?
Has anyone here broke a stock LS1 crank and if so what power were you making and what were you doing when it happened?
High boost from forced induction, lots of spray?
I heard it can handle nearly 1000 HP, is this true and how safe will it be if I install forged pistons and rods and boost the motor from turbo around 15lbs or more? Cranks are a little spendy and dont wanna buy one if dont need to but also dont wanna ruin a motor for not spending a few more hundred on one.
Any info would be greatly appreciated, thanks.
Reliably? Around 6-800hp. Anymore than that and you're risking it...not saying it won't hold that power but I would not want to risk that. Some people have gone bigger than that and are ok so far.
Depends on how much you plan on making with those 15lbs. If it's around 700 at the wheels you will be ok with the OEM crank and some forged pistons and rods. It's all in the tune, so make sure that's done correctly.
Do a search for a user y2khawk. There is a thread I remember reading where a few of the big hp guys had ran the stock crank.
EDIT: found it!
https://ls1tech.com/forums/forced-in...k-1200-hp.html
EDIT: found it!
I think I will clean up the stock crank and replace all bolts with ARP that I can to help keep things tight and in place and call it good since I dont think I will be making the power to ruin it or push beyond its limits and if so wont be all the time as wont be daily driven and what not. I think and (knock on wood) hope I will be ok. I have an excellent tuner and will make sure I will be set. Thanks for all the info everyone, much appreciated.
EDIT: found it!
EDIT: found it!
