Patriot spring install, major snag
Old Oct 18, 2011 | 03:14 PM
thunderstruck507's Avatar
Default Patriot spring install, major snag
On top of everything else that's gone wrong today, I didn't realize the Patriot springs required special valve seals.
My ls6 heads have a one peice seal/base that the patriot springs wont even slide over.
My springs that I picked up secondhand did not include the seals. Can these be obtained from the dealer or what?
Old Oct 18, 2011 | 04:06 PM
01ssreda4's Avatar
You can find these as an option at the auto parts stores if you want to buy them locally.
Old Oct 18, 2011 | 04:46 PM
ZeeOSix's Avatar
Nope ... the dealer will only have the one piece OEM seals. You're going to have to go aftermarket for them, and they will be the ones that just slide over the top of the valve guide. You should also have new spring seats too since the guide seals you need will not have the built in spring seat like the OEM seals have.
Old Oct 18, 2011 | 04:51 PM
I have the steel seats and titanium retainers, just no seals.
01SSreda4: thanks, you don't happen to know a part number do you? can check oreilleys and az, parts plus was already checking for me so they might be able to get them
Old Oct 18, 2011 | 06:55 PM
3rdCoastPowerSports's Avatar
if they are the stock guides and stock valves, comp cam #511-16, not sure about other brands parts numbers
Old Oct 18, 2011 | 06:59 PM
also measure the ID of your steel seats and make sure they are not for the larger bronze guides... i bought my spirngs, seat and retainers secondhand and the seats were for the bronze guides, so now im shopping for the correct size steal seat/locators... stock is .505" larger bronze is .56x" ID
Old Oct 19, 2011 | 04:29 AM
vettenuts's Avatar
If they are stock heads, the older (pre-2002) GM valve seals will work. I have had issues with aftermarket coming off of the guides so tend to stick with OEM for valve seals. You can also contact Patriot and just order the seals by themselves.
Old Oct 19, 2011 | 09:19 AM
Do the older factory seals have seats attached? I'm already at 1.785" install height so I don't think I want them on there.
Thanks in advance
Old Oct 19, 2011 | 10:14 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We stock the seats you need!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 19, 2011 | 11:56 AM
apparently the Fel Pro part number for the 2 peice seals is SS70945 for a set of 16 in case anyone finds this thread helpful
old cam is out, 8 dead lobes and 4 are severely deep
car should run better than 111mph with the new setup I think haha
Old Oct 19, 2011 | 04:55 PM
vettenuts's Avatar
Thanks in advance
No, the one piece seal/seat was introduced in 2002.
