my batterie died and now my keyless entry wont work
Have you tried this?
To reprogram your keyless remote to the car follow this procedure.
-Remove the Radio fuse in the lower corner of your fuse panel inside the car (There's two radio fuses, the one in the bottom corner is the right now).
-Insert the key and cycle the key three times, ending in the "ON" position. The door locks should cycle indicating that the vehicle is in program mode.
-with your keyless remote, hold the unlock and lock buttons, then release and hold the lock button.
-The door locks will cycle indicating that programming was successful. Turn the Key off and you are done.
