g5x3 cam or ms4 cam help me pick one
Old 10-28-2011, 08:13 PM
mikemunoz's Avatar
Default g5x3 cam or ms4 cam help me pick one
i have the g5x3 cam spec r .234 .242 .600/.610 112 ls1. I love it but it keeps breaking my valve springs. i run the patriots duel gold .650... dont know y... this guy offers to trade me a MS4 113 lsa... What u guys think i should do?
Old 10-28-2011, 08:37 PM
BuckaroooZ28's Avatar
i have the t-rex cam and i used to break springs until i got the prc springs, good up to .660 lift been on the car for 5 years and i shift@6900 ive put atleast 40k on these springs
Old 10-28-2011, 09:54 PM
blackls1ta00's Avatar
since i have afr heads i run the afr springs upgraded to 650 lift,g5x3 is a great cam!!!
Old 10-28-2011, 10:01 PM
mikemunoz's Avatar
What springs you thing i should get
Old 10-28-2011, 10:43 PM
X2Z28's Avatar
I've had an X2 and an X4, they were both great. Only broke 1 spring when I had the X2. I run the partiot dual golds. If you keep breaking springs I would put a new set on before changing the cam, just my opinion though. How much do you drive the car?
Old 10-28-2011, 10:54 PM
99Bluz28's Avatar
Do you let the engine warm up before you take off driving, or skip the warm up?
Old 10-28-2011, 11:14 PM
mikemunoz's Avatar
the springs are brand new, and ya i do let the car warm up before i take off. swapping out the cam tomorrow morning ms4 113 lsa
Old 10-29-2011, 12:53 AM
99Bluz28's Avatar
I don't see the cam being the issue, that's really not a lot of lift. Were the springs set to the correct install height?
Old 10-29-2011, 10:19 AM
whatsa347's Avatar
MS4 is gonna be harder on your springs, especially if you live in the upper rpm's
Old 10-29-2011, 03:59 PM
1mean96ss's Avatar
MS4 is around .650 lift goodluck
Old 10-29-2011, 06:25 PM
lumina_cr8's Avatar
3 years with the g5x3 114 lsa cam , I love it
i have a single comp cam springs
+1
Old 10-29-2011, 06:35 PM
LilJayV10's Avatar
This x50
What's the install height? Coil bind?
You said you keep breaking springs. Is it the same set? Did you replace the broken spring and let the others go? How many miles are on the springs, where they broken in properly?
It really doesn't make sense to put another cam in there thinking that will fix the problem.
Old 10-29-2011, 06:47 PM
99Bluz28's Avatar
Especially considering he's going with a cam with aggressive/high lift lobes!
Quick Reply: g5x3 cam or ms4 cam help me pick one
